Civil engineering feature implementation (Transportation Engineering)
ebrahim raeyat
Re: Civil engineering feature implementation (Transportation Engineering)
Postby ebrahim raeyat » Fri Sep 13, 2019 3:04 pm
Kunda1 wrote:
Thu Sep 12, 2019 8:55 pm
ebrahim raeyat wrote:
Thu Sep 12, 2019 1:29 am
Version: 0.19.16718 (Git)
we're on revision 0.19.18198
you should probably update.
Thanks, certainly.
ebrahim raeyat
Postby ebrahim raeyat » Fri Sep 13, 2019 3:06 pm
Joel_graff wrote:
Thu Sep 12, 2019 9:49 pm
I haven't really been doing a good job making the user interface accessible, I admit.
CSV fucntionality is broken and deprecated. I won't be using it going forward.
You can import an XML file by pressing CTRL_Shift_A. That will let you open a file dialog to pick the XML file. That *should* work. Hakan seemed to make it work on his own LandXML files, anyway.
I really should try to update the commands, though. I've really ignored that stuff because I figured no one was paying attention anyway. ;)
I am interesting in Tracker, it is so nice. thanks
Joel_graff
Postby Joel_graff » Fri Sep 13, 2019 3:50 pm
It's a work in progress, but it will be very useful for the vertical alignment tool as well... when I get around to it.
Joel_graff
Postby Joel_graff » Sat Sep 14, 2019 11:55 am
Courtesy of a comment by @ebrahim raeyat, I've made a small update to the UI:
Screenshot from 2019-09-14 06-48-50.png (12.08 KiB) Viewed 617 times
The black page and arrow icon opens the LandXML importer. The four connected dots next to it starts the horizontal alignment tool, once a horizontal alignment is selected. The other buttons are functions that don't do anything (the template library) or are used to test the tracker classes.
HakanSeven12
Postby HakanSeven12 » Sat Sep 14, 2019 12:53 pm
https://www.flaticon.com/free-icon/xml_337959
https://www.flaticon.com/free-icon/xml_136526
Joel_graff
Postby Joel_graff » Sat Sep 14, 2019 3:57 pm
Well, then. Would have been nice to know about that before I spend a half hour making an icon in InkScape. :lol:
ebrahim raeyat
Postby ebrahim raeyat » Sat Sep 14, 2019 7:08 pm
Thank you so much. I will follow your work. I am planning to develop a WB for concrete detailing. It will help me for this.
Joel_graff
Postby Joel_graff » Sat Sep 14, 2019 7:42 pm
Great!
HakanSeven12
Postby HakanSeven12 » Sun Sep 15, 2019 1:50 pm
Looks better :)
Postby Kunda1 » Sun Sep 15, 2019 3:11 pm
Just an FYI to remember the work that @agryson did. He even made some guidelines for FC, Artwork_Guidelines
