FreeCAD Trails Workbench (Transportation and Geomatics)
Re: Geomatics Workbench
I created a pull request with some changes to make all the commands working (import point/surface/contours/sections).
I will be glad if someone can check the dev branch before the merge.
Okay, it's done.
Trying to use GeoData and Geomatics again, but unfortunately not working
Import OSM (GeoData)
Running same Import OSM on Geomatics WB
FreeCAD_0.19-17646-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
on Fedora 30
Python version: 3.7.3
Running the Python command 'Geodat_importOSM' failed:
File "<string>", line 476, in Activated
File "/home/paullee/.FreeCAD/Mod/geodata/geodat/import_osm.py", line 27, in <module>
from say import *
No module named 'say'
I try to read data from cache file ...
/home/paullee/.FreeCAD/geodat3/50.340722-11.232647-0.25
no cache file, so I connect to openstreetmap.org...
http://api.openstreetmap.org/api/0.6/map?bbox=11.229140688639552,50.338475818508535,11.236153311360448,50.342968181491464
File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 128, in import_osm2
f = open(fn, "r")
FileNotFoundError: [Errno 2] No such file or directory: '/home/paullee/.FreeCAD/geodat3/50.340722-11.232647-0.25'
During handling of the above exception, another exception occurred:
File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 695, in downloadData
rc = import_osm2(float(b), float(l), float(s)/10, self.root.ids['progb'], self.root.ids['status'], elevation)
File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 141, in import_osm2
import requests
ModuleNotFoundError: No module named 'requests'
on Fedora 30
Features from the GeoData Workbench are only included as quicklinks in the Geomatics Workbench.
In my opinion this link and the underlying code should be removed in the next release.
I add an issue in the github repo for that.
From the error message, I thought GeoData in Geomatics has some fixes done ?
Trying Import Point Files... with these errors message:-
XYZ data (~120mB) from
https://bezreg-koeln.nrw.de/brk_interne ... e/dgm1.zip
Any idea?
File "/home/paullee/.FreeCAD/Mod/Geomatics/Data/ImportPointFile.py", line 302, in ImportFile
self.FileReader(File, "Import")
File "/home/paullee/.FreeCAD/Mod/Geomatics/Data/ImportPointFile.py", line 256, in FileReader
float(row[Z])))
ValueError: could not convert string to float:
Any idea?
- HakanSeven12
Your data file has more than one whitespace between coordinates. The wb only allow one whitespace.
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
If you ticked "Process elevation data" it's not working. Also you need to install required python packages.
- HakanSeven12
I fixed what I can. But some part of it still don't works.
- Joel_graff
Might want to put implementing a text file parser on the list to avoid this in the future. I imagine there's plenty of format variations that would have to be coded for...HakanSeven12 wrote: ↑Fri Sep 20, 2019 8:45 am Your data file has more than one whitespace between coordinates. The wb only allow one whitespace.
