glider workbench
looo
Re: glider workbench
Postby looo » Mon Sep 23, 2019 11:00 am
Mx74
Postby Mx74 » Mon Sep 30, 2019 2:08 pm
https://vimeo.com/360754349
Next step for OpenGlider ? :-)
looo
Postby looo » Mon Sep 30, 2019 5:44 pm
by Mx74 » Mon Sep 30, 2019 3:08 pm
thanks for the link. We are developing also in this direction, but this is very difficult stuff:
https://github.com/booya-at/paraFEM
datecru
Postby datecru » Tue Nov 12, 2019 12:16 am
Hi, anyone have a video tutorial or could explain the installation process?, i try everything and i can't do it :cry:
looo
Postby looo » Tue Nov 12, 2019 10:10 am
Using conda:
conda create --name <env_name> freecad openglider  -c openglider -c freecad/label/dev -c conda-forge
to run freecad:
conda activate <env_name>
FreeCAD
For conda install the latest version of miniconda (currently python3.7):
https://docs.conda.io/en/latest/miniconda.html
For help on how to use conda, best to have a look at the docs available:
or search for a video tutorial
other packagemanager:
If you want to install on linux distro. Best to have a look at the dependency section of the library and install the libraries with system package-manager. https://github.com/booya-at/OpenGlider/ ... quires.txt
Once done clone the openglider library and install it:
git clone https://github.com/booya-at/OpenGlider
cd OpenGlider
pip install -e --no-deps .
But this way some features are not enabled (mainly some meshing tools and flow-simulation).
svenair
Postby svenair » Sun Nov 17, 2019 11:06 am
looo wrote:
Fri Dec 11, 2015 4:56 pm
Announcing the glider workbench, a gui for OpenGlider in freecad. Development is still ongoing, but I thought it is time to show the development state. If someone is interested in testing or developing I can give instructions on how to install OpenGlider and this workbench.
It looks like it is a very useful and nice Workbench!
I had Interest to play with this..
But to install looks for me a bit difficult..
I had many happy Time under Paragliders and now more under Hanggliders..
https://www.youtube.com/watch?v=rKJmh9sq5x8&t=242s
Are you in this Buisyness?
I started Paragliding 1989..
Postby chrisb » Sun Nov 17, 2019 11:21 am
This workbench seems to be interesting for quite a lot of people. Should it be integrated in the Addon manager?
looo
Postby looo » Sun Nov 17, 2019 1:20 pm
Not possible to due difficult (compiled) dependencies (mainly parabem, meshpy). We provide easy installation with conda. In my mind this is a good compromise between maintainability and simplicity to install.
looo
Postby looo » Sun Nov 17, 2019 1:27 pm
Not really, but we are planning to release one of the designs mentioned in this topic.
svenair
Postby svenair » Sun Nov 17, 2019 6:06 pm
Interesting..
The Software makes a good look for work, when it is easyer to install or when I'm having some Time, I will test.
