[Request for Comment] Assigning Ctrl+/ to open the Preference Dialog or About FreeCAD dialog?
Post by Kunda1 »
Right now, AFAICT, there is not shortcut that opens the Preferences Editor
I vote that the shortcut key:
Ctrl + /
be assigned to that operation.
Thoughts ?
kisolre
Re: [Request for Comment] Assigning Ctrl+/ to open the Preference Dialog
Post by kisolre »
Mhy do we need a shortcut for this? I open it about once a month so shortcut will not help anyway. Once you tune your preferences you rarely need to change something.
Post by Kunda1 »
kisolre wrote: Sun Oct 06, 2019 6:36 am Mhy do we need a shortcut for this? I open it about once a month so shortcut will not help anyway. Once you tune your preferences you rarely need to change something.
I've encountered many applications that actually assign a keyboard shortcut to open up their preferences. It's also something that's very common on MacOS.
kisolre wrote: Sun Oct 06, 2019 6:36 am Why do we need a shortcut for this? I open it about once a month so shortcut will not help anyway. Once you tune your preferences you rarely need to change something.
+1
I am really a keyboard fan, and I know the situation where I fiddle with the preferences many times a day, but usually it is really rarely used.
Kunda1 wrote: Mon Oct 07, 2019 12:20 am It's also something that's very common on MacOS.
The shortcut on MacOS is usually "CMD+," Using something different seems to cause more confusion than having no shortcut at all.
Jee-Bee
Post by Jee-Bee »
+1 for shortcut.
Specially if it is cmd+, OR ctrl+,
Because it is easy to misread, I want to clarify: on MacOS the shortcut is CMD_key and additionally KOMMA_key.
kisolre
Post by kisolre »
Can you press those with one hand under MacOS?
Post by wmayer »
Everybody can assign a shortcut (via the Customize command) to the function if desired.
kisolre wrote: Mon Oct 07, 2019 9:48 am Can you press those with one hand under MacOS?
On my keyboard: Yes. I don't know if that is the default on Mac keyboards, but I have a CMD key on both sides of the SPACE. My keyboard is small enough (or my hands are so huge) that I can reach from the left CMD key to the PLUS key on the right.
Post by wmayer »
Qt offers the class QKeySequence that defines platform-dependent short cuts:
from PySide import QtGui
ks=QtGui.QKeySequence(QtGui.QKeySequence.Preferences)
ks.toString()
ks.isEmpty()
However, on Windows it doesn't set a short cut. Can anyone test on macOS or Linux?
