It is not an issue of TabBar, it's an issue of FreeCAD in general. The problem occurs with all toolbars. But I don't know, how to reproduce it, it doesn't appears everytime.Kunda1 wrote: ↑Sat Oct 05, 2019 5:06 pmIs there an issue open for this ?
Edit: Maybe open one at https://github.com/triplus/TabBar/ ?
Redesign the UI and UX
Re: Redesign the UI and UX
what I have been looking for is to be able to customize the layout of existing functions, both in the toolbars (this mostly exists) but also the menus, contextual-menus, panels ... and that such a customisation could be saved in a file, and be portable from one workstation to another. My workflow seems to be very different from that of the main FreeCAD developers.
@rahamanshaber
You have to know, that is not sure, that your changes will be merged! It may well be that your changes won't merged and you work was for nothing (ok, not for nothing, but not the new standard layout).
But first name a few ideas you want to change, so we can give you our opinion.
usbhub
usbhub
I know that, that's why i asked.usbhub wrote: ↑Tue Oct 08, 2019 4:57 pm @rahamanshaber
usbhub
I just want the disabled button to hide auto. Also the tasks tab when it is not in use and it should appear in a separate widget in right side.
- adrianinsaval
+1 to this, but hiding disabled buttons seems counterproductive to merahmanshaber wrote: ↑Wed Oct 09, 2019 12:45 pm Also the tasks tab when it is not in use and it should appear in a separate widget in right side.
+1 (especially the counterproductive hidden buttons)adrianinsaval wrote: ↑Thu Oct 10, 2019 12:08 am+1 to this, but hiding disabled buttons seems counterproductive to merahmanshaber wrote: ↑Wed Oct 09, 2019 12:45 pm Also the tasks tab when it is not in use and it should appear in a separate widget in right side.
I just want to ask when you what much time it took you to learn the freeCAD?usbhub wrote: ↑Fri Oct 11, 2019 4:02 pm+1 (especially the counterproductive hidden buttons)adrianinsaval wrote: ↑Thu Oct 10, 2019 12:08 am+1 to this, but hiding disabled buttons seems counterproductive to merahmanshaber wrote: ↑Wed Oct 09, 2019 12:45 pm Also the tasks tab when it is not in use and it should appear in a separate widget in right side.
I don't see any apps disable the feature instead of hiding. I think it is not a good ux.
How about a settingto hide disabled tools
- adrianinsaval
Most app I know don't hide, actually. How else would you know you can do something?rahmanshaber wrote: ↑Sun Oct 27, 2019 12:43 pm I don't see any apps disable the feature instead of hiding. I think it is not a good ux.
This is more reasonable
I think you did not get my point after all.adrianinsaval wrote: ↑Mon Oct 28, 2019 4:48 amMost app I know don't hide, actually. How else would you know you can do something?rahmanshaber wrote: ↑Sun Oct 27, 2019 12:43 pm I don't see any apps disable the feature instead of hiding. I think it is not a good ux.This is more reasonable
For now hiding option will be better. So how you guys will implement it.
