Part->Chamfer does not work
koluna
Re: Part->Chamfer does not work
Postby koluna » Thu Oct 10, 2019 7:49 pm
I took your SVG. The Sweep tool works. But the result is wrong...
What Sketch did you use to form a shape for Sweep using?
raty.FCStd
(261.31 KiB) Downloaded 10 times
koluna
Postby koluna » Fri Oct 11, 2019 7:54 am
pl7i92LCNC wrote:
Thu Oct 10, 2019 5:44 pm
if yes it is your svg generation on inkscape
use normal svg and 96DPI
What did you mean?
Where are these settings?
It is awful, terrible and horrible... :(
Anybody, please, try a Sweep tool in my file: path3384 (or Sketch) and Sketch001.
I simplified my path and it does not work again... :(((((((((((((((((((((((((((((((((((((((((((
I use Inkscape 0.91.
koluna
Postby koluna » Fri Oct 11, 2019 8:18 am
FreeCAD_0.19-18403-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage also crashes...
Postby chrisb » Fri Oct 11, 2019 8:46 am
If you have simplified the path please upload the file again.
koluna
Postby koluna » Fri Oct 11, 2019 9:00 am
Sure...
I am sorry, my brain is burnt...
3.FCStd
(294.7 KiB) Downloaded 9 times
Postby chrisb » Fri Oct 11, 2019 4:29 pm
The crash happens on the first sharp right bend if going from the section to the left. My guess is, that the path segments are very slightly non tangential and that this causes problems. Have you tried converting the path into a sketch?
koluna
Postby koluna » Fri Oct 11, 2019 6:20 pm
The crash hapens on the first sharp right bend if going from the section to the left. My guess is, that the path segments are very slightly non tangential and that this causes problems.
Did you mean a selected segment of the path (path3384 or Sketch) on an attached screenshot?
Yes, I have. It is "Sketch" in my file. I used it with a Sweep tool. I had a same result...
drawing.svg
(8.66 KiB) Downloaded 6 times
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 11, 2019 6:36 pm
i will make you a video
it is 10min to the print in Blender FROM WWW image grap
no problem with path sweep or .....
this kind of work is not on FreeCAD
thats why we got multiple systems for CAD/Nurb/svg/png/dxf
Bildschirmfoto von 2019-10-11 20-34-47.png (504.38 KiB) Viewed 306 times
koluna
Postby koluna » Fri Oct 11, 2019 6:55 pm
I will be very glad for your manual, thanks :)
It seems, it will need to study Blender or something like one...
I wanted to use only FC, but I already use Inkscape :lol:
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 11, 2019 7:37 pm
the importent one is gimp
to offset the shape
in inkscape
you need to tweaken also the settings on Bitmap Vectorising
there are options on the Reiter
as pixel limits from 2->4
the shape precision to be svg from 0,6 to 1or even 1,2
there is another option that gives you the toleranz from 0,2 set it to 0,6
i guss you already did get the selection on png load to get smooth corners
there is lots to do bevor Fc or Blender that makes live very easy
i atached all files for tutorial A
the blend file is to big to be atached
dino_tutorial_A.zip
(196.6 KiB) Downloaded 10 times
