I have come across a situation where using a formula in the attachment offset of a sketch results in a dependency graph failure.
I wonder if I am doing something wrong or if this is perhaps a bug or a known issue.
Test:
Open the attached file.
Create a dependency graph: OK.
Change the Attachment Offset X value of Sketch004 (Label=WindowOutline). Use this formula: Sketch001.AttachmentOffset.Base.x
Roy_043 wrote: ↑Fri Oct 11, 2019 2:10 pm
Thanks for your answers. On the download page I find that I am using the current stable Windows version: 2.38. Maybe @kisolre is using a dev version?...
dot -v
dot - graphviz version 2.40.1 (20161225.0304)
This tells me that version 2.40 was released back in 2016. And Ubuntu is known for having old packages. Probably there is an even newer version right now. If I may guess, I'd say the version 2.38 that you reference is quite old.
Thanks. But I still get the error.
Note: Where I said "Sketch004 (Label=WindowOutline)" in the OP, I should have said "Sketch002 (Label=WindowOutline)". This may have confused the issue.
