Info Workbench - Help with icons please.
Intermezzo
Re: Info Workbench - Help with icons please.
Postby Intermezzo » Thu Nov 12, 2015 2:49 pm
mario52 wrote:hi
the file is false zip you must delete ".zip" and use
or what's the problem ?
or the link my macros to gists https://gist.github.com/mario52a (FCInfo last page)
mario
:roll: OK. I feel like an idiot.
But it works now :D
mario52
Postby mario52 » Thu Nov 12, 2015 4:12 pm
hi
no problem thanks for report
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
roberto52
Postby roberto52 » Thu Mar 01, 2018 7:56 am
I have installed the macro ObjectInfo
When I open info a warning appear on the screen
No module named PyQt4
Can you help me ?
thanks
jmaustpc
Postby jmaustpc » Thu Mar 01, 2018 1:58 pm
Can you help me ?
thanks
Please start by providing your version data in the manner explained in the forum rules link above the Help forum.
sgrogan
Postby sgrogan » Thu Mar 01, 2018 4:12 pm
Can you help me ?
thanks
You have an old version of the macro that uses PyQt4, FreeCAD now uses Pyside instead.
You can get the latest version of the macro and the icons here:https://gist.github.com/mario52a/8d40ab6c018c2bde678f
Instructions here: https://www.freecadweb.org/wiki/index.p ... cro_FCInfo
"fight the good fight"
roberto52
Postby roberto52 » Fri Mar 02, 2018 6:01 am
thanks for the quick answer
herrdeh
Postby herrdeh » Fri Oct 11, 2019 7:31 pm
Hello,
love this macro, I think these essential infos should be part of "FC core"...
Now I found a little glitch - not sure whether it's my wrong. I can nicely find out lengths of sketcher lines, but with the sketch "open" (means: sketch is in editable mode), I get wrong results:
Bildschirmfoto von 2019-10-11 21-19-39.png (43.81 KiB) Viewed 526 times
Bildschirmfoto von 2019-10-11 21-19-52.png (31.96 KiB) Viewed 526 times
Bildschirmfoto von 2019-10-11 21-20-04.png (22.81 KiB) Viewed 526 times
Bildschirmfoto von 2019-10-11 21-20-14.png (31.64 KiB) Viewed 526 times
Bildschirmfoto von 2019-10-11 21-20-28.png (34.34 KiB) Viewed 526 times
It's not a big deal, but can be a problem if you do not know that you MUST ONLY USE FCInfo, if sketcher is closed. So a closer examination might be worth...
Cheers,
Wolf
herrdeh
Postby herrdeh » Fri Oct 11, 2019 7:34 pm
NB:
30/05/2019 ver "01.21-rmu"
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
Here comes my example file.
FCInfo.FCStd
(4.75 KiB) Downloaded 21 times
herrdeh
Postby herrdeh » Fri Oct 11, 2019 7:38 pm
NB2:
I think it would be a good idea if the macro would read from global settings about "digits behind decimal point".
mario52
Postby mario52 » Sat Oct 12, 2019 9:33 pm
hi
tanks for report but I do not know how to correct in sketcher open
yes for the next version and save the config in file, icon include in macro and other little adding
mario
