Part->Chamfer does not work
Re: Part->Chamfer does not work
Postby chrisb » Fri Oct 11, 2019 8:24 pm
Back to FreeCAD: in the attached files I made all "almost tangents" really tangents. Then the sweep succeeds.
Bildschirmfoto 2019-10-11 um 22.23.44.png (14.42 KiB) Viewed 548 times
3_cb.FCStd
(356.7 KiB) Downloaded 12 times
pl7i92LCNC
Postby pl7i92LCNC » Sat Oct 12, 2019 6:43 am
Back to FreeCAD: in the attached files I made all "almost tangents" really tangents. Then the sweep succeeds.Bildschirmfoto 2019-10-11 um 22.23.44.png
is this made by HAND or on some auto tangent
can you give us NOOB a quick advice on how you did that what WB path modified to a sketch or ....
Thanks
pl7i92LCNC
Postby pl7i92LCNC » Sat Oct 12, 2019 6:44 am
and here is the Blender Tutorial on that i hope it is allowed here to get other non CAd software discriped
phpBB [video]
koluna
Postby koluna » Sat Oct 12, 2019 6:48 am
Thanks!
I am comparing path3384 and Sketch in your file...
Did you correct Sketch?
Why did you correct Sketch002?
There are few differences, they are almost identical!
How did you make it?
Which principles did you use?
I cannot understand why the tangentiality is very important for path...
koluna
Postby koluna » Sat Oct 12, 2019 6:53 am
Yes, yes, yes! Chrisb, it is very important for us!
koluna
Postby koluna » Sat Oct 12, 2019 6:55 am
Thanks a lot! I will check it out bit later...
Postby chrisb » Sat Oct 12, 2019 6:57 am
That's a leftover from previous tries. Sometimes the sharp corners create self intersections of the sweep which make the sweep fail. You can move it back to the outside and report back if it works or not.
I removed coincidences and created tangents whereever the looked tangent. I only left those untouched which had a clearly visible angle.
I cannot understand why the tangentiality is very important...
Because the geometric kernel cannot handle them properly, I would guess it's due to some kind of rounding issue.
Postby chrisb » Sat Oct 12, 2019 7:03 am
I used Sketcher. With Box selection I select one of the angent looking connections. The connection show green. While watching the solver message use Delete key to remove the coincidence. The number of degrees of freedom (DOF) raises by two. Now box select the same point again - this selects both endpoints - and apply a tangency constraint. The number of DOF decreases by 3.
koluna
Postby koluna » Sat Oct 12, 2019 6:58 pm
It works.
I repeated your way and a Sweep tool was worked. Thanks.
But, how can I correct the self-intersection in a result Sweep?
I should not correct Sketch001 (or a bit). Should I correct a path (my contour - Sketch)? Should I alter the corner in the path?
Postby chrisb » Sat Oct 12, 2019 9:18 pm
I try to avoid this situation by either not having such sharp corners (radius of bends should exceed thickness of the sweep section) or I place the section appropriately.
