Feature #4162 - Draft: change pointer 'Pick Radius' based on if the user is editing or selecting
This thread is a discussion thread for issue #4162 - Draft Feature: change pointer 'Pick Radius' based on if the user is editing or selecting
Re: Feature #4162 - Draft: change pointer 'Pick Radius' based on if the user is editing or selecting
Great, you can assign it to me since it's concerning edit command I guess.
Done (added you as a 'Developer', congrats )
Wow, that's a huge resposibility, hope I haven't been too hasty . Just to be sure if i got it right:
- we should create a new Parameter for "DraftEditPickRadius" (in BaseApp\Preferences\Mod\Draft) (Float);
- this line https://github.com/FreeCAD/FreeCAD/blob ... dit.py#L68 should fetch it;
- in the Draft user preferences a new entry should give the user the chance to modify it (maybe in snap and grid sheet?);
AFAICT, that makes sense.carlopav wrote: ↑Sun Oct 13, 2019 9:04 pm Wow, that's a huge resposibility, hope I haven't been too hasty . Just to be sure if i got it right:
Yea, that works though not ideal. Having it's own section makes sense to me...like 'Mouse'.
Does something like this make sense at the beginning of Draft Edit?
It works as expected: if the parameter exhist it returns != 0 and the self.pick_radius can get it. Otherwise the parameter is set.
I just find it not so elegant...
EDIT: This is the second option. perhaps it's better:
if FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetInt("DraftEditPickRadius") == 0:
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").SetInt("DraftEditPickRadius", 20)
self.pick_radius = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetInt("DraftEditPickRadius", 20)
param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft")
self.pick_radius = param.GetInt("DraftEditPickRadius", 0)
if self.pick_radius == 0:
param.SetInt("DraftEditPickRadius", 20)
self.pick_radius = 20
Yea, this does seem more sleekcarlopav wrote: ↑Wed Oct 16, 2019 9:43 pm
EDIT: This is the second option. perhaps it's better:Code: Select all
param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft") self.pick_radius = param.GetInt("DraftEditPickRadius", 0) if self.pick_radius == 0: param.SetInt("DraftEditPickRadius", 20) self.pick_radius = 20
- DeepSOIC
BTW, pick radius can be also manipulated with
EDIT: and then I realized that advice wasn't asked for. If you already know, sorry for the noise.
Gui.ActiveDocument.ActiveView.getViewer().getPickRadius()
Gui.ActiveDocument.ActiveView.getViewer().setPickRadius(15)
That's even cooler! Thanks @DeepSOICDeepSOIC wrote: ↑Thu Oct 17, 2019 12:07 am BTW, pick radius can be also manipulated withEDIT: and then I realized that advice wasn't asked for. If you already know, sorry for the noise.Code: Select all
Gui.ActiveDocument.ActiveView.getViewer().getPickRadius() Gui.ActiveDocument.ActiveView.getViewer().setPickRadius(15)
Here you can find the PR: https://github.com/FreeCAD/FreeCAD/pull/2642.
Hope it works since i'm not able to compile and this was the first time trying to edit the preferences UI.
