Radio controlled airplane
Re: Radio controlled airplane
I've built and flown many airplanes of this size in the past. The key is to make them as light as possible. I will add some 1/32" liteply pieces at the front and back of the spar between the inner four ribs. Since it is so thin, it can be bent across the dihedral/sweep break without dividing it into two pieces. That should be more than enough reinforcement.
I'm not planning to add any type of gyro. Again, keeping it light is key. I also have a micro helicopter that I fly with the camera, without any electronic stabilization except for on the tail, and this will be a piece of cake compared to that. It will require nearly-calm skies, though.
yes, that should help.montagdude wrote: ↑Sun Oct 13, 2019 6:16 pm I will add some 1/32" liteply pieces at the front and back of the spar between the inner four ribs. Since it is so thin, it can be bent across the dihedral/sweep break without dividing it into two pieces. That should be more than enough reinforcement.
All framed up and ready for covering. Here are a mock-up pictures.
- IMG_9943.JPG (813 KiB) Viewed 2787 times
- IMG_9942.JPG (878.88 KiB) Viewed 2787 times
All done. If the weather forecast is right, I should be able to do the first flights tomorrow morning.
- IMG_9955.JPG (511.24 KiB) Viewed 2661 times
- IMG_9954.JPG (440.07 KiB) Viewed 2661 times
- IMG_9953.JPG (527.33 KiB) Viewed 2661 times
Maiden flight success! Thanks for looking.
Awesome - thanks for sharing! Now I wanna build an airplane ...
Congratulations to build, flight and landing!
Thanks for sharing this nice job, from CAD to real object in action
Well done!
Well done!
Thanks, everyone. FreeCAD was a pleasure to use for this project.
Is this small battery pack at the left front all what it needs to fly it?
