[Solved] Error shown when adding a Assembly 2 constraint
daaan
Postby daaan » Sat Oct 19, 2019 5:57 pm
Error shown when adding a Assembly 2 constraint in the assembly,
no module named 'objectProxy'
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
<class 'TypeError'>: Object of type 'FeaturePython' is not JSON serializable
  File "/usr/lib/python3.6/json/__init__.py", line 231, in dumps
    return _default_encoder.encode(obj)
  File "/usr/lib/python3.6/json/encoder.py", line 199, in encode
    chunks = self.iterencode(o, _one_shot=True)
  File "/usr/lib/python3.6/json/encoder.py", line 257, in iterencode
    return _iterencode(o, 0)
  File "/usr/lib/python3.6/json/encoder.py", line 180, in default
    o.__class__.__name__)
vocx
Re: Error shown when adding a Assembly 2 constraint
Postby vocx » Sat Oct 19, 2019 6:21 pm
Do not use Assembly2 because it is obsolete. Use A2plus Workbench instead. You have to re-create the assembly in this workbench.
daaan
Postby daaan » Sat Oct 19, 2019 8:24 pm
ok, thanks,
now, how could I make an animation with the dof and constraints in A2plus Workbench ?
daaan
Postby daaan » Sat Oct 19, 2019 10:04 pm
ok, I see,
