SOLVED: python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll not found
HarryvL
Post by HarryvL »
Hi I have switched to Windows (again) and am trying to compile the latest development version. I am using the following tools and resources:
Cmake 3.15.4
MVSC 2019 (16.3.5)
FreeCADLibs_12.1.2_x64_VC15
Neither Cmake nor MVSC cause any trouble, but when I execute FreeCAD.exe I get:
The code execution cannot proceed because xxxx was not found
where xxxx = python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll, respectively
I checked and the path FREECAD_LIBPACK_DIR is correct and the bin/libs directory of FreeCADLibs_12.1.2_x64_VC15 does contain a python3.lib file.
I am not sure how to proceed.
Re: python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll not found
Post by wmayer »
Either you copy all dlls from the libpack's bin directory to FreeCAD's bin directory or to save disk memory set the PATH environment variable to include the libpack's bin directory.
HarryvL
Post by HarryvL »
Thank you @wmayer. I will give it a try.
vocx
Post by vocx »
HarryvL wrote: Sun Oct 20, 2019 6:40 pm Hi I have switched to Windows (again) and am trying to compile the latest development version. I am using the following tools and resources:
Did you read CompileOnWindows? It was recently re-written by a Windows user, so I suspect the information is up to date.
HarryvL
Post by HarryvL »
I did
HarryvL
Post by HarryvL »
wmayer wrote: Mon Oct 21, 2019 6:28 am
This removed the error message. However, now FC (debug) aborts at start-up with a debug error ("abort() has been called"). But it runs ok from the command line. I will try the release version next.
Post by wmayer »
Qt must be able to find its qwindows.dll/qwindowsd.dll and if you use the Qt version of the libpack it usually fails because the built-in path names usually are different. So, for this case create the directory platforms inside FreeCAD's bin directory and copy the above dlls there.
HarryvL
Post by HarryvL »
Brilliant! That worked. Thanks Werner
HarryvL
Post by HarryvL »
Having said that, in FC I now get several PySide2 errors
During initialization the error "No module named 'PySide2'" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\AddonManager\InitGui.py
Please look into the log file for further information
During initialization the error "No module named 'PySide2'" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Arch\InitGui.py
During initialization the error "No module named 'PySide2'" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Draft\InitGui.py
During initialization the error "invalid syntax (<string>, line 41)" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\OpenSCAD\InitGui.py
During initialization the error "No module named 'PySide2'" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Tux\InitGui.py
CommandManager::addTo() try to add an unknown command (Std_AddonMgr) to a widget!
  File "<string>", line 2, in <module>
  File "C:\Users\hvlan\Documents\FC_019\build\Mod\Start\StartPage\StartPage.py", line 27, in <module>
    import six
<class 'ModuleNotFoundError'>: No module named 'six'
  File "<string>", line 48, in Initialize
  File "C:\Users\hvlan\Documents\FC_019\build\Mod\Fem\femcommands\commands.py", line 26, in <module>
    from .manager import CommandManager
  File "C:\Users\hvlan\Documents\FC_019\build\Mod\Fem\femcommands\manager.py", line 32, in <module>
    import femtools.femutils as femutils
  File "C:\Users\hvlan\Documents\FC_019\build\Mod\Fem\femtools\femutils.py", line 45, in <module>
    from PySide import QtGui
  File "C:\Users\hvlan\Documents\FC_019\build\Ext\PySide\__init__.py", line 2, in <module>
    from PySide2 import __version__
Post by wmayer »
For my FreeCAD version I set the PATH variable:
set PATH=C:\Projects\FreeCADLibs_12.1.3_x64_VC15\bin;C:\Tools\git\bin;%PATH%
When running FreeCAD and entering
import six
six
I get
<module 'six' from 'C:\\Projects\\FreeCADLibs_12.1.3_x64_VC15\\bin\\lib\\site-packages\\six.py'>
and
from PySide2 import QtGui
QtGui
gives
<module 'PySide2.QtGui' from 'C:\\Projects\\FreeCADLibs_12.1.3_x64_VC15\\bin\\lib\\site-packages\\PySide2\\QtGui.cp36-win_amd64.pyd'>
For the debug version the output is similar. The only difference is that QtGui shows
<module 'PySide2.QtGui' from 'C:\\Projects\\FreeCADLibs_12.1.3_x64_VC15\\bin\\lib\\site-packages\\PySide2\\QtGui_d.cp36-win_amd64.pyd'>
