FreeCAD as pre-post processor for MBDyn
Re: FreeCAD as pre-post procesor for MBDyn
Post by bernd »
vocx wrote: Mon Oct 07, 2019 5:40 pm By the way, when you are building paths, it's best to use Python's os.path functions. I would also avoid variables with double underscores as these are typically reserved for special internal properties.
__dir__ + "/MBDyn/MBDynCase.mbd"
os.path.join(__dir__, "MBDyn/MBDynCase.mbd")
Found there is something even better a few weeks ago ... https://docs.python.org/3/library/pathlib.html On my own code I have switched to pathlib, but on such a big code base as FEM it would be quit some work and for sure some problems will come up. Thus I leave it for now with os.path even if we have in FEM on windows some paths with mixed slash and backslash. :o I works without problems but I do not like it ...
If I would do something new I would take pathlib right from the beginning.
vocx
Post by vocx »
bernd wrote: Mon Oct 07, 2019 7:28 pm ...
I guess that's fine if you know you won't use Python 2 at all. But also, pathlib looks a bit over engineered (object oriented of course). I guess it's fine if you are going to handle a lot of paths, but if you are doing simple concatenation to get just one file I think it's overkill, and os.path is simpler.
josegegas
Post by josegegas »
Made some progress with my animation algorithm....
phpBB [video]
In a similar way as the reaction forces, I'd lice to animate the reaction torque over the joints. MBDyn gives the torque too, but i don't have many ideas on how to animate a torque. Forces are simple. Length of the line is force magnitude, and line direction is force direction. Does anyone have an idea how to animate a torque? Can one animate arcs with FreeCAD, as I do with the lines for the forces? Suggestions?
Cheers.
Reason: added video tags
UR_
Post by UR_ »
josegegas wrote: Thu Oct 10, 2019 2:02 pm Does anyone have an idea how to animate a torque?
Usually double headed arrows are used to visualize torque vectors
Post by bernd »
UR_ wrote: Thu Oct 10, 2019 4:42 pm
same for me in structural engineering
BTW: nice pic. Is this FreeCAD?
josegegas
Post by josegegas »
Hi. Couple of questions:
When the user changes a property of a scripted object, the "onChanged" method gets executed. Is there a way to change the values of other properties of the same object, from within the "onChanged" method? I want the "onChanged" to do some calculations using the value of the changed property, and update other properties with the results. How can I achieve this?
The second question is: there are:
App::PropertyDistance
App::PropertyLength
App::PropertySpeed
App::PropertyAcceleration
App::PropertyForce
App::PropertyPressure
But there is no App::PropertyMass? At least I get an error saying App::PropertyMass does not exist. I would like to store something like:
Quantity(self.volume*self.density,Unit('kg'))
in a property, but I don't want to use a simple string property...
Cheers!!
microelly2
Post by microelly2 »
josegegas wrote: Fri Oct 25, 2019 5:45 am When the user changes a property of a scripted object, the "onChanged" method gets executed. Is there a way to change the values of other properties of the same object, from within the "onChanged" method? I want the "onChanged" to do some calculations using the value of the changed property, and update other properties with the results. How can I achieve this?
You can do this but you have to add some code to stop recursive calls of the onChanged method.
Is this an FEM question or a general python programming question?
josegegas
Post by josegegas »
Simulating the tennis racket theorem with MBDyn + FreeCAD :D
https://www.youtube.com/watch?v=On72bOD ... e=youtu.be
Here's a video explaining this behavior:
https://www.youtube.com/watch?v=1VPfZ_XzisU
And the original MBDyn exercise:
https://www.sky-engin.jp/en/MBDynTutori ... hap09.html
Enjoy!!
Post by Kunda1 »
josegegas wrote: Fri Oct 25, 2019 10:17 pm Simulating the tennis racket theorem with MBDyn + FreeCAD :D
That's awesome!
BTW, is this something that you think eventually can be modeled ?
phpBB [video]
(we can't view .gifv :( )
https://www.reddit.com/r/Automate/comme ... _pendulum/
