[solved] vase rotation extrusion helix and profile
pl7i92LCNC
Re: vase rotation extrusion helix and profile
Postby pl7i92LCNC » Fri Oct 25, 2019 1:47 pm
so this is the nearest i coudt get on loft
i cand make it smooth it is ruled it fails on smoothness (rule=false)
there is somthing wrong in the sketch flow or the rotation
more inspection needed
the Filesize on 16 sketches has jumped over 2MB as from 20kb with 6 sketches
has someoen a logical reason on this
can i clear the file to a standard
Postby chrisb » Fri Oct 25, 2019 2:26 pm
It seems as if you have simply enlarged thebottom sketch, which results in different radii for the outer skeleton ribs. the image posted above did not have this, only the distance between the ribs varied.
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 25, 2019 3:18 pm
i teard it down now
800kb
WHY cand i select the next sketch it fails on generate the loft
it w
vas_2.FCStd
(799.79 KiB) Downloaded 45 times
orkes wit regular (straigt but not on smooth
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 25, 2019 5:34 pm
and the FINAL
what i did start all over one Sketch profile one contour
i did in DRAFT clone only the BASE 14 times ((Clones only from Base Sketch)) and moved eatch clone up to ponts where the contour changes
then i scaled eatch clone to the contour shape
then i rotated eatch clone acording to the Height of the clone i wanted 90deg in totel at 60mm geigt so factor 1,5 height to rotation
now in PART make a loft from the clones starting base and adding them all failed managed to go until last 3 to first loft
then i did the rest 3 into another loft
and final fused them together
Wollah a nearly perfect contour shaped VASE took in total from start 10h but as you know how to do it it is 20minutes max
Filesize now 300kb
vas_neu.FCStd
(253.05 KiB) Downloaded 20 times
papyblaise
Re: [solved] vase rotation extrusion helix and profile
Postby papyblaise » Sat Oct 26, 2019 6:10 am
As you know a vase is empty :?: Are you able to shell yours :?:
GlouGlou
Postby GlouGlou » Sat Oct 26, 2019 8:08 pm
Here, fully parameterized, and be a shell. ;)
Loft run well only a degree 3.
vase3.FCStd
(56.35 KiB) Downloaded 22 times
Postby chrisb » Sat Oct 26, 2019 8:43 pm
Impressive solutions! (But I hope I will not have any of these vases in my home, but that's a matter of taste :lol: )
