Back port commits to 0.18 branch
Re: Back port commits to 0.18 branch
Postby Kunda1 » Mon Oct 28, 2019 10:38 am
sgrogan wrote:
Sat Oct 26, 2019 5:17 pm
https://github.com/FreeCAD/FreeCAD/releases/tag/0.18.4
I hope to fill it out by next weekend.
Heads up, the 0.18.4 revision number should be 16145 not 16131
sgrogan
Postby sgrogan » Tue Oct 29, 2019 11:01 pm
We need to disable the auto deploy for conda based builds based on looo's post above.
"fight the good fight"
looo
Postby looo » Wed Oct 30, 2019 9:41 am
I didn't mean to not create 0.18.4 builds which are hopefully uploaded soon.
Postby Kunda1 » Wed Oct 30, 2019 11:08 am
It's good that we're ironing out all these details and getting better at releases.
where's our checklist for such things?
For example on my end:
manuall update the script that updates(*) the AppImage page which is actually updating 2 wiki templates: And also submitting a PR to FreeCAD-Homepage
https://github.com/FreeCAD/FreeCAD-Home ... b701266046
* The script only tracks the development version not stable.
looo
Postby looo » Wed Oct 30, 2019 5:09 pm
My attempt to build 0.18.4 didn't succeed because of conda-build 3.18 introduced a slow-down during a library checking process and circle-ci stops the build because of "Too long with no output (exceeded 10m0s)".
ref.:
https://github.com/conda-forge/conda-bu ... issues/118
https://github.com/conda/conda-build/issues/3775
I will trigger the builds again once a new conda-build version is available.
edit.: After doing some modification to the build-scripts I was able to force conda using a conda-build-version other than 3.18.10. So 0.18.4 builds are uploaded and should be used for the next appimage/dmg.
sgrogan
Postby sgrogan » Thu Oct 31, 2019 9:58 pm
https://github.com/FreeCAD/FreeCAD/releases/tag/0.18.4 :D @looo is awesome!
0.18.16146?
kkremitzki
Postby kkremitzki » Thu Oct 31, 2019 11:29 pm
As much as I love juggling these 5-digit numbers I can't wait until we get them out of our release version numbers and back to referring to development builds only.
looo
Postby looo » Fri Nov 01, 2019 9:20 am
Struggling with the weekly builds nearly every week, I didn't expect the old recipe to work out of the box...
Anyway osx is seeing brew-issues again. So this might need some time to be solved. (Last time we saw such errors it somehow got sorted by itself.)
https://travis-ci.org/FreeCAD/FreeCAD-A ... 7378#L3276
Hmm, I think it shouldn't be too difficult to change this. But I do not really feel responsible for this part and changing this might break other stuff too. So I guess it's best to ask @triplus or @kunda to make this change.
triplus wrote:
Kunda1 wrote:
Postby Kunda1 » Fri Nov 01, 2019 12:58 pm
The stable builds shouldn't have revision numbers, IMO.
So I'm :+1: for removing them. Downstream package managers will adapt as well.
uwestoehr
Postby uwestoehr » Fri Nov 01, 2019 1:10 pm
:+1: from me too.
