Omitting one or more sides when contouring/profiling
Re: Omitting one or more sides when contouring/profiling
Postby chrisb » Sat Nov 02, 2019 7:11 am
mlampert wrote:
Sat Nov 02, 2019 3:24 am
In case somebody has some time for testing,
Sounds great! Is this a pure python solution, so that I could just replace the Mod/Path directory?
mlampert
Postby mlampert » Sat Nov 02, 2019 4:40 pm
Not quite, it loads the dialog from the tresource file - so you would have to regenerate the Path, or edit PathDressupPathBoundaryGui.py to load the file directly. If you do the latter it is a pure python only implementation.
Postby chrisb » Sat Nov 02, 2019 6:17 pm
Thanks for the (slightly disappointing :) ) answer. If you are only halfway confident, I vote for just including it in 0.19. After all it is a development version.
mlampert
Postby mlampert » Tue Nov 05, 2019 8:04 pm
I hope this demonstrates how it works and what it does:
Postby chrisb » Tue Nov 05, 2019 8:38 pm
I guess the position of the box is controlled by its placement? And non-rectangular areas can be defined via existing solid? Then it is exactly what was needed since long time.
mlampert
Postby mlampert » Tue Nov 05, 2019 11:24 pm
It's probably not that obvious from the gif but Stock002 in this example is a regular box, you can resize it, rotate it, move it around. And like the regular Job.Stock it can be a Box, a Cylinder, an extension of the model's BoundBox or an arbitrary solid.
EDIT: It was @schnebeck who provided the foundation - so all beers should go his way!
Postby chrisb » Wed Nov 06, 2019 7:24 am
Schnebeck, I owe you indeed a beer. Markus, I owe you at least a crate of beer.
sliptonic
Postby sliptonic » Wed Nov 06, 2019 1:29 pm
Awesome work guys! This is great.
RatonLaveur
Postby RatonLaveur » Wed Nov 06, 2019 6:25 pm
That is awesome! I just played with it and cut random areas of a complex profile with the laser.
Look it even brought Sliptonic back from the land of the living!
schnebeck
Postby schnebeck » Fri Nov 08, 2019 11:02 am
In case somebody has some time for testing, I did a POC for the "Boundary Dressup":
https://github.com/mlampert/FreeCAD/tre ... nt-dressup
Cool stuff! I donate my beer if this gets merged into the main devel tree soon :mrgreen:
Thanks a lot
Thorsten
