Assembly4: XLink absolute filepath problem
FCuser2019
Postby FCuser2019 » Sun Oct 27, 2019 4:52 pm
Hi, I tried the tutorial https://github.com/Zolko-123/FreeCAD_As ... TORIAL1.md, I saved my files asm_tuto1.FCStd, axis.FCStd, bearing.FCStd in a directory I called "Tut1", everything works.
However, if I rename the directory with a different name, and try to open the file asm_tuto1.FCStd again, the assembly is not displayed and I get the following error messages:
<PropertyLinks> PropertyLinks.cpp(2566): document not found /home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/axis.FCStd
<PropertyLinks> PropertyLinks.cpp(2566): document not found /home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/bearing.FCStd
Enumeration index -1 is out of range, ignore it
3.68e-07 <App> Document.cpp(2549): asm_tuto1#axis.LinkedObject: Link not restored
Linked object: Model
Linked file: /home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/axis.FCStd
9.6373e-05 <App> Document.cpp(2549): asm_tuto1#bearing_1.LinkedObject: Link not restored
Linked file: /home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/bearing.FCStd
0.000144121 <App> Document.cpp(2549): asm_tuto1#bearing_2.LinkedObject: Link not restored
0.0001885 <App> Document.cpp(2549): asm_tuto1#bearing_3.LinkedObject: Link not restored
I downloaded all the files from https://github.com/Zolko-123/FreeCAD_As ... 4_Example2, I put them in a directory I called "Ex2", if I open the file asm_V4.FCStd the assembly is displayed correctly. If I rename the "Ex2" directory and open the file asm_V4.FCStd again, it is displayed without any problems.
This seems to be an absolute filepath problem in the links to objects.
Inside the Document.xml file of my asm_tuto1.FCStd I've seen that all XLinks have the absolute filepath:
<XLink file="/home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/bearing.FCStd"... />
<XLink file="/home/test/Documenti/FreeCAD/Forum/Assemly4/Tutorials/Tut1/axis.FCStd"... />
instead in Document.xml of asm_V4.FCStd all XLinks have the relative filepath:
<XLink file="Crankshaft.FCStd"... />
<XLink file="Cylindre.FCStd"... />
<XLink file="Bielle/asm_Bielle.fcstd" ... />
<XLink file="Piston/Piston.FCStd" ... />
Is there a way to tell Assembly4 to use the relative filepath when creating an assembly?
Thank you in advance for your help.
(Sorry for my english, I have used an online translator)
Assembly4 version: 0.6.3
OS: Linux Mint 18.1 (MATE/mate)
Version: 0.19.18614 (Git) AppImage
Hash: efd55884ad7d40e77571a60c5bb906bbd8d1cbbd
Python version: 3.7.3
Qt version: 5.12.5
Locale: Italian/Italy (it_IT)
Re: Assembly4: XLink absolute filepath problem
Postby chrisb » Sun Oct 27, 2019 5:03 pm
Please edit your previous post and put the log output in code tags </>. That makes your post easier to read because it is easier to distinguish between system output and your text.
Zolko
Postby Zolko » Sun Oct 27, 2019 6:01 pm
ah yeah, you're right. I hadn't seen that, I'll have to investigate. realthunder, any ideas ? Is there a way to specify relative and absolute paths for App::Links ?
realthunder wrote:
Thu Oct 24, 2019 12:36 am
Zolko
Postby Zolko » Mon Oct 28, 2019 8:26 am
So, the difference comes from between FreeCAD-asm3 and FreeCAD-0.19-pre. I did the exact same thing in both, and -asm3 gives relative paths while 0.19-pre gives absolute paths:
  • create 3 new documents
  • save them as asm, part1, part2, in the same directory
  • close them
  • re-open them
  • create a link (not Assembly4 link, a pure App::Link) in asm
  • assign the linked part as part1
  • create a link in asm
  • assign the linked part as part2
  • save
then when I rename the directory, -asm3 finds the links again while 0.19-pre looses them.
realthunder, did you modify the paths behaviour between -asm3 and 0.19-pre ?
Zolko
Postby Zolko » Mon Oct 28, 2019 8:29 am
EDIT: duplicate message
realthunder
Postby realthunder » Mon Oct 28, 2019 9:28 am
Thanks for reporting. That's a serious problem. Yes, something wrong when merging this part. I'll fix it soon.
FCuser2019
Postby FCuser2019 » Mon Oct 28, 2019 8:45 pm
Zolko, thanks for your quick investigation.
So let's wait for good news from realthunder.
adrianinsaval
Postby adrianinsaval » Thu Nov 07, 2019 9:51 pm
Sorry to bother you but are there any news on this front?
realthunder
Postby realthunder » Fri Nov 08, 2019 12:09 am
It got stuck in one of my feature branch. I have just split it out and submitted the PR here.
adrianinsaval
Postby adrianinsaval » Fri Nov 08, 2019 12:47 am
Thanks for the quick response! :D
