strange result from the constraint transformation
S-Y.Chen
Postby S-Y.Chen » Fri Nov 08, 2019 8:29 am
I tried to work on the example on this thread https://forum.freecadweb.org/viewtopic.php?t=20238
in which the pin support on the both ends was transformed to cylindrical coordinate system, and the radial displacement is suppressed.
After the analysis, the result of the deformation seems a little strange. The shape of the pin holes remains circles, but it is deformation in the radial direction (the holes become larger).
Did I do anything wrong ? Or this is just the numerical error that cause it looks like the holes are enlarging ?
Regard
S-Y. Chen
Re: strange result from the constraint transformation
Postby bernd » Fri Nov 08, 2019 10:36 am
would you post your FreeCAD file and your FreeCAD version info?
S-Y.Chen
Postby S-Y.Chen » Fri Nov 08, 2019 4:34 pm
Here it is.
Try to scale up the deformation, you will see the holes are enlarged.
>>>>>> Version info
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Chinese/Taiwan (zh_TW)
>>>>>> Version info
Regards
S-Y. Chen
Test_beam.fcstd
(715.53 KiB) Downloaded 24 times
S-Y.Chen
Postby S-Y.Chen » Fri Nov 22, 2019 4:20 am
anyone has any idea about this problem ?
Regards
S-Y.Chen
fandaL
Postby fandaL » Fri Nov 22, 2019 8:36 pm
As regards model settings I don't see any mistake.
Enlarging holes in the deformed view (especially when scaled) are due to way of displaying deformation. Transformation to constrain radial displacement around holes created local cylindrical coordinate system. However, by default *.frd file (output from CalculiX) contains results in the global coordinate system, so the tangential displacement is shown in the rectangular c.s. which appears as a rotation and a bit of hole diameter increase.
UR_
Postby UR_ » Sat Nov 23, 2019 1:35 pm
Screenshot 006.png (61.95 KiB) Viewed 362 times
