FreeCAD fail to build with OCE (community eddition)
cbalint
Post by cbalint »
* As per description: https://www.freecadweb.org/tracker/view.php?id=4190
This [PR#2680](https://github.com/FreeCAD/FreeCAD/pull/2680) introduced a header file [Standard_Handle.hxx](https://github.com/FreeCAD/FreeCAD/blob ... lper.h#L26) not available in OCE community edition.
Unsure if it is intentional, is FreeCAD dropping OCE support.
Error is obvious:
[ 35%] Building CXX object src/Mod/TechDraw/App/CMakeFiles/TechDraw.dir/AppTechDrawPy.cpp.o
In file included from /home/cbalint/rpmbuild/BUILD/FreeCAD/src/Mod/TechDraw/App/AppTechDrawPy.cpp:73:
/home/cbalint/rpmbuild/BUILD/FreeCAD/src/Mod/TechDraw/App/DrawDimHelper.h:26:10: fatal error: Standard_Handle.hxx: No such file or directory
26 | #include <Standard_Handle.hxx>
Re: FreeCAD fail to build with OCE (community eddition)
Post by wmayer »
As far as I can see that's the one and only location in the FreeCAD code base that includes this header. As OCE/OCC internally includes the appropriate header file to offer the Handle() class it's superfluous to explicitly include it in FreeCAD code, too.
So, in this case it's trivial to fix the build for OCE but in the long-term OCE support might be dropped since the major Linux distributions switch back to OCC.
vocx
Post by vocx »
cbalint wrote: Fri Nov 08, 2019 5:57 pm ...
I haven't seen an official announcement, however, OCE, the community edition, has been pretty much ignored by FreeCAD since 2017 or so.
See I don't think anybody of the major developers tests their code against OCE, only the official OCCT 7.x series.
That FreeCAD still compiled against OCE was incidental; I don't think anybody explicitly wanted to retain "support" for it. It seems to me OCE is de facto obsolete, even if there was no official announcement.
sukoi26
Post by sukoi26 »
Hello,
i suggest to change the line code
by
# include <Geom2d_Curve.hxx>
it work on OCE result info :
OS: Debian GNU/Linux bullseye/sid (GNOME/gnome)
Version: 0.19.18702 (Git)
Build type: Unknown
Hash: aab61f3e151e65975e370b4d8ff3611d6355730c
Python version: 3.7.5
Qt version: 5.12.5
OCC version: 6.9.1.oce-0.18
sukoi26
Post by sukoi26 »
test wih OCC
Build type: Unknown
Qt version: 5.12.5
wandererfan
Post by wandererfan »
wmayer wrote: Sat Nov 09, 2019 11:02 am git commit ac4e23012a4b6
Woke up this morning and this was already fixed! Thank you.
cbalint
Post by cbalint »
Thank you Folks !
sukoi26
Post by sukoi26 »
thank a lot wmayer for the commit :)
