Cannot edit job after saving
masterchippy
Postby masterchippy » Sun Nov 10, 2019 1:44 pm
Just getting into using path WOrkbench for some cnc work. Generally love how it has developed. However went back to a project a day later and can not edit job when I reopen the file. Double clicking Job in the model history takes me to the transform instead of the job setup. This only happens when I save and then restart freecad then reopen file.
Forgot after re opening the Job icon in the history changes to that of DressupTag.
Secondly Adaptive pocket seems to be too high and I have to subtract the depth from start and finish settings.
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
driving wheel0.8.FCStd
(284.88 KiB) Downloaded 7 times
Re: Cannot edit job after saving
Postby chrisb » Sun Nov 10, 2019 2:45 pm
You have somehow messed up your job. It is usually a sort of container with subelements in the tree. Can you repeat this behaviour with a very simple setup, such as
- a cube
- a job using the default tool
- a contour path?
masterchippy
Postby masterchippy » Sun Nov 10, 2019 3:25 pm
Hi thanks for reply. just created a block then a path job and a simple contour(does it on any operation. Saved the file and closed Freeecad. Re-opened file in freecad. Screenshot before and after shows Job icon changes to a dressup icon after re-opening. Have tried several times and on 2 different laptops.
regards
before and after.jpg (56.32 KiB) Viewed 291 times
masterchippy
Postby masterchippy » Sun Nov 10, 2019 3:34 pm
Repeated again but without template. Same result and cannot edit job
Screenshot from 2019-11-10 15-34-51.png (119.08 KiB) Viewed 285 times
Postby chrisb » Sun Nov 10, 2019 6:05 pm
Works here (almost, but that seems to be something different, I'll open a new topic). Can you load the attached file? It's Cube+Path+Contour.
OS: macOS High Sierra (10.13)
Version: 0.19.18694 (Git)
Hash: c3ba04183e016e15410d84bae4d00556d22c7da5
Python version: 3.7.3
Qt version: 5.12.5
cubeContour.FCStd
(11.76 KiB) Downloaded 7 times
masterchippy
Postby masterchippy » Sun Nov 10, 2019 6:30 pm
As with my example loads but shows dressup icon for job. Think I might try backing up and deleting config to see if it is ok from scratch. Thanks
mlampert
Postby mlampert » Sun Nov 10, 2019 6:32 pm
Therre's something bad going on, can you check if there are any errors showing up in the Report View, and if so post those?
masterchippy
Postby masterchippy » Sun Nov 10, 2019 6:37 pm
Still the same after resettin config. Funnily it only happens if I close freecad and re launch. closing the file and re-opening without closing freecad works ok with the job icon still tere and able to edit job settings.
masterchippy
Postby masterchippy » Sun Nov 10, 2019 6:44 pm
Thanks this is report view message on opening file. I am not good at programming but it tells me something is not right!
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathJobGui.py", line 1328, in <module>
PathGuiInit.Startup()
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathGuiInit.py", line 51, in Startup
from PathScripts import PathDressupPathBoundaryGui
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathDressupPathBoundaryGui.py", line 27, in <module>
import PathScripts.PathJobGui as PathJobGui
<class 'AttributeError'>: module 'PathScripts' has no attribute 'PathJobGui'
masterchippy
Postby masterchippy » Sun Nov 10, 2019 7:03 pm
Just tried loading with the appimage version. No problem with that but it is an older version of 0.19. Shame because even with an SSD the laoding time for the appimage verion is horrendous so I stick with the PPA.
