How to make obj with ViewProvider from outside FreeCAD
Post by bernd »
How do I create objects with ViewProviders from outside FreeCAD?
import FreeCAD
import Part
import Arch
fname = "archobj"
doc = FreeCAD.newDocument(fname)
Arch.makeComponent(Part.makeBox(300,200,2500))
doc.saveAs("/tmp/" + fname + ".FCStd")
creates an obj with VP if run inside FreeCAD but does not if run in Python outside FreeCAD.
cheers bernd
Re: How to make obj with ViewProvider from outside FreeCAD
Post by bernd »
noone here who needs view provider outside FreeCAD?
furti
Post by furti »
Until now I didn't have a usecase for this.
But the problem might be, that Arch.makeComponent checks if a GUI is initialized.
if FreeCAD.GuiUp:
    ArchComponent.ViewProviderComponent(obj.ViewObject)
Without the GUI stuff and coin3D initialized, creating a ViewProvider will not work I think. So my guess it, you have to initialize the FreeCAD Gui before creating the component.
But I don't know if this is possible to do from outside of FreeCAD.
vocx
Post by vocx »
bernd wrote: Sun Nov 03, 2019 6:19 pm ...
Sorry, Bernd, but I still don't understand your question. What the hell does it mean creating a viewprovider outside of FreeCAD? A view provider is part of FreeCAD, how can you create one without it?
furti
Post by furti »
I think what he means is to execute the snippet in his first post in a external python interpreter and save a document including the view provider.
But the viewprovider is not created because there is no FrreCADGui available.
Post by bernd »
furti wrote: Fri Nov 15, 2019 5:47 pm I think what he means is to execute the snippet in his first post in a external python interpreter and save a document including the view provider.
exactly. This is just an example. I would like to create a whole building in a script in a python interpreter outside FreeCAD.
use case: I have set up a python based BIM model server and would like to export the data into FreeCAD document format.
Post by Kunda1 »
This is a good feature to have for sure. Not sure about the technicality of implementing it.
