[Bug 4196] Bug in expression parser
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Postby babaroga » Sun Nov 17, 2019 11:34 pm
Lately, expression parser is not working with "/" sign any more.
When I try to enter eg. 12/2 in some of dimension fields, textbox does not accept "/" sign after first member in expression. It works on second member eg. 12+12/2.
All other operations +, -, *, sqrt etc works OK.
So, try to type in any of eg. X, Y or Z:
12/2 - does not work
(12+5)/2 - does not work
(12)/2 - does not work
12+3/2 -works
Everything works OK if I type it as formula
My FreeCAD was built from master 30 mins ago
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.18753 (Git)
Hash: c0a80e1a9a5683404fe506201d0ee74b28ea819d
Python version: 3.7.4
Qt version: 5.13.2
OCC version: 7.4.0
Should I file a Bug report?
Re: Bug in expression parser
Postby chrisb » Sun Nov 17, 2019 11:47 pm
I can confirm. If I remove the the dimension "mm" then 12/2 is accepted.
Postby chrisb » Sun Nov 17, 2019 11:51 pm
It still worked in 0.19.17798.
babaroga
Postby babaroga » Mon Nov 18, 2019 1:06 pm
