[Solved] Application error on Mantis
Post by wmayer »
When trying to access our bug tracker there is now a big red banner with this message:
APPLICATION ERROR #2510
The "FreecadThemePlugin" Class is not defined in Plugin "FreecadTheme".
Please use the "Back" button in your web browser to return to the previous page. There you can correct whatever problems were identified in this error or select another action. You can also click an option from the menu bar to go directly to a new section.
Is there anybody else who has the same problems?
Reason: Changed to [SOLVED]
Re: Application error on Mantis
I see the same (in german language).
Post by Kunda1 »
I see it as well.
Need to ping @kkremitzki
kkremitzki wrote::bell:
kkremitzki
Post by kkremitzki »
Sorry, this was me, I'll try to fix it ASAP.
Jee-Bee
Post by Jee-Bee »
The FC forum is screwed up as well.
2019-11-18 17_06_01-Application error on Mantis - FreeCAD Forum.png (46.56 KiB) Viewed 1573 times
2019-11-18 17_05_44-P037_JBW_MONITOR_ORIGINAL_2 Rev_ 00.2+ In Work  (Active) wtws___Windchill_BBAC_i.png
2019-11-18 17_05_44-P037_JBW_MONITOR_ORIGINAL_2 Rev_ 00.2+ In Work (Active) wtws___Windchill_BBAC_i.png (62.57 KiB) Viewed 1573 times
kkremitzki
Things should hopefully be fixed now, a force refresh may be needed with e.g. Ctrl+F5 (depending on your browser), please let me know if any issues are still present after that.
Everything back to normal here.
Jee-Bee
Post by Jee-Bee »
thanks for the quick fix!!
Re: [Solved] Application error on Mantis
Post by Kunda1 »
Thanks @kkremitzki and everyone who participated. Marked the thread [Solved]
Post by wmayer »
The error is back.
