Trying to unwrap a surface
erich
Postby erich » Mon Nov 18, 2019 9:00 pm
I'm trying to unwrap two cylinders with the ends cutout to make paper templates so I can cut out the tubes for a suspension a-arm.
Searching online gives a macro to install, "Unroll Ruled Surface" I've installed it (and it's full of mixed tabs/spaces which I fixed locally), it doesn't work for my simple model.
I've attached the file hoping someone can educate me on what I'm doing wrong.
Thanks,
Eric
I'm running the daily builds:
OS: Ubuntu 16.04.6 LTS (XFCE/xubuntu)
Version: 0.19.
Python version: 3.5.2
Locale: English/Canada (en_CA)
SolidSockets.FCStd
(108.1 KiB) Downloaded 16 times
erich
Re: Trying to unwrap a surface
Postby erich » Wed Nov 20, 2019 9:09 pm
OK, I'm trying a different plan of attack but hit another weird problem.
I managed to get what the model view says is two wires, but one of them is in two parts and I cannot get any tool or combination of tools to join it into a functional single wire.
If I select the two wires in the model view and "Create a ruled surface" from them, only half of one is used. I've tried upgrading, join, downgrading into pieces and re-upgrading. Pretty much every combination I could think of to try and get the two halves of the wire joined into a single wire.
What simple thing am I missing?
The object "Wire" is the one I can't get to join.
Thanks,
Eric
RuledSurface4.FCStd
(349.11 KiB) Downloaded 13 times
ulrich1a
Postby ulrich1a » Wed Nov 20, 2019 10:36 pm
I think the macro "Unroll Ruled Surface" has issues and does not work as expected. A year ago, I started to write my version of it. It was written with python 2. I will check tomorrow, if it can be used under actual FreeCAD.
Ulrich
looo
Postby looo » Thu Nov 21, 2019 5:25 am
If you can create a mesh, it's possible to use the unwrap mesh command from mesh-part workbench.
erich
Postby erich » Thu Nov 21, 2019 7:08 am
I don't think that workbench exists today. At least I can't find any recent reference to it.
UR_
Postby UR_ » Thu Nov 21, 2019 9:24 am
A little example, how to unwrap a tube.
remarks:
- Cylinder-connector has an angle less than 360°, because mesh needs a cut. In this example 355° for better visibility only.
- Cylinder's face is extracted by Lattice2 workbench (please see adddon manager), but only to preserve parametrics.
- Face is meshed by "Mesh Design" workbench (netgen, very fine)
- Unwrapped by "Mesh Design" "Unwrap Mesh"
Screenshot 002.png (50.21 KiB) Viewed 587 times
TubeConnector.FCStd
(140.85 KiB) Downloaded 15 times
version:
OS: Windows 10 (10.0)
Version: 0.19.18760 (Git)
Hash: ef73ab5f3a330d3c44138f23290f8c9f7a334caf
Python version: 3.7.3
Qt version: 5.12.1
erich
Postby erich » Thu Nov 21, 2019 6:39 pm
remarks:
Thanks for the help, except the "Mesh Design" workbench doesn't have "Unwrap Mesh" anywhere that I can find.
Is my two week old daily build too old?
Thanks,
Eric
UR_
Postby UR_ » Thu Nov 21, 2019 7:22 pm
Don't think so.
I'm a windows user (conda build), and here it is available for longer time.
Screenshot 003.png (28.05 KiB) Viewed 466 times
Perhaps we have to ask a packager
sgrogan wrote: :bell: Has Linux conda appimage 0.19 "unwrap mesh" support :?
erich
Postby erich » Thu Nov 21, 2019 7:38 pm
This is what I get:
I guess it's not in the daily builds?
ulrich1a
Postby ulrich1a » Thu Nov 21, 2019 10:31 pm
Here is my macro as work in progress. It is not perfect. Some faces do overlap in difficult cases. It should unwrap shapes with flat and cylindrical and conical surfaces. But there are more cases than I can ever test.
Ulrich
unroll7p3.py.zip
Macro to unwrap, work in slow progress
(8.48 KiB) Downloaded 32 times
