Very good hint, I still have a lot to learn, when it comes to Linux...
Here's the output of
cmake -DPYTHON_EXECUTABLE=/usr/bin/python2.7 \ -DPYTHON_INCLUDE_DIR=/usr/include/python2.7m \ -DPYTHON_LIBRARY=/usr/lib/arm-linux-gnueabihf/libpython2.7m.so \ -DPYTHON_PACKAGES_PATH=/usr/local/lib/python2.7/dist-packages/ ../freecad-source
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Compiler: GNU, version: 9.2.1
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: /usr/local
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.13.4
-- Found PythonInterp: /usr/bin/python2.7 (found version "2.7.17")
-- Found PythonLibs: /usr/lib/arm-linux-gnueabihf/libpython2.7.so (found suitable exact version "2.7.17rc1")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.67.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/lib/arm-linux-gnueabihf/libxerces-c.so
-- Found ZLIB: /usr/lib/arm-linux-gnueabihf/libz.so (found version "1.2.11")
-- PyCXX found:
-- Headers: /home/tiedemate/freecad-source/src
-- Sources: /home/tiedemate/freecad-source/src/CXX
-- Version: 6.2.8
-- Found OCC: /usr/include/opencascade (found version "7.3.0")
-- -- Found OCE/OpenCASCADE version: 7.3.0
-- -- OCE/OpenCASCADE include directory: /usr/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/lib/arm-linux-gnueabihf
-- The imported target "vtkGUISupportQt" references the file
"/usr/lib/arm-linux-gnueabihf/libvtkGUISupportQt-7.1.so.7.1.1"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkGUISupportQtSQL" references the file
"/usr/lib/arm-linux-gnueabihf/libvtkGUISupportQtSQL-7.1.so.7.1.1"
-- The imported target "vtkParseOGLExt" references the file
"/usr/bin/vtkParseOGLExt-7.1"
-- The imported target "vtkRenderingPythonTkWidgets" references the file
"/usr/lib/arm-linux-gnueabihf/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
"/usr/bin/vtk"
-- The imported target "pvtk" references the file
"/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/include
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- We guess that libmed was built using hdf5-openmpi version
-- Checking for one of the modules 'hdf5-openmpi'
-- Checking for one of the modules 'ompi-cxx'
-- Found SWIG: /usr/bin/swig3.0 (found version "3.0.12")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.7", minimum required is "2.91.0")
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found
-- Found Qt4: /usr/bin/qmake (found suitable version "4.8.7", minimum required is "4.5.0")
-- Found Freetype: /usr/lib/arm-linux-gnueabihf/libfreetype.so (found version "2.9.1")
-- Found OpenGL: /usr/lib/arm-linux-gnueabihf/libOpenGL.so
-- Found OpenGLU: /usr/lib/arm-linux-gnueabihf/libGLU.so
-- Checking for module 'Coin'
-- No package 'Coin' found
-- Coin3D libraries found
-- Found Spnav: /usr/lib/libspnav.so
-- Using default python: -python2.7
-- libshiboken built for Release
-- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
matplotlib not found, Plot module won't be available.
-- Platform is 32-bit
-- /home/tiedemate/freecad-build/src/Base/TypePy.cpp
-- /home/tiedemate/freecad-build/src/Base/BaseClassPy.cpp
-- /home/tiedemate/freecad-build/src/Base/BoundBoxPy.cpp
-- /home/tiedemate/freecad-build/src/Base/CoordinateSystemPy.cpp
-- /home/tiedemate/freecad-build/src/Base/PersistencePy.cpp
-- /home/tiedemate/freecad-build/src/Base/VectorPy.cpp
-- /home/tiedemate/freecad-build/src/Base/MatrixPy.cpp
-- /home/tiedemate/freecad-build/src/Base/RotationPy.cpp
-- /home/tiedemate/freecad-build/src/Base/PlacementPy.cpp
-- /home/tiedemate/freecad-build/src/Base/AxisPy.cpp
-- /home/tiedemate/freecad-build/src/Base/UnitPy.cpp
-- /home/tiedemate/freecad-build/src/Base/QuantityPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectPy.cpp
-- /home/tiedemate/freecad-build/src/App/ExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/ExtensionContainerPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/GroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/LinkBaseExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectGroupPy.cpp
-- /home/tiedemate/freecad-build/src/App/GeoFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/App/GeoFeatureGroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/OriginGroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/PartPy.cpp
-- /home/tiedemate/freecad-build/src/App/ComplexGeoDataPy.cpp
-- /home/tiedemate/freecad-build/src/App/PropertyContainerPy.cpp
-- /home/tiedemate/freecad-build/src/App/MaterialPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Points/App/PointsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/FacetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshPointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfConicPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BodyBasePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ConicPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/CirclePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/EllipsePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/HyperbolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ParabolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/OffsetCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryIntExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryStringExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryBoolExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryDoubleExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BoundedCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/LinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/LineSegmentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BezierCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BSplineCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PlanePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ConePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/CylinderPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SpherePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ToroidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BezierSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PlateSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PartFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/AttachExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Part2DObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/AttachEnginePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/App/BodyPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/App/FeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchGeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/ExternalGeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/TrajectoryPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/WaypointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/RobotObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Import/App/StepShapePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/App/FemMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/CommandPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/PathPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/ToolPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/TooltablePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/AreaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/FeatureAreaPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- python27
-- found Boost: 1_67
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib/arm-linux-gnueabihf
-- Boost_LIBRARIES is: /usr/lib/arm-linux-gnueabihf/libboost_python27.so
-- area module (for Path Workbench) will be installed to: lib
-- /home/tiedemate/freecad-build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Measure/App/MeasurementPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawPagePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewDimExtentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawHatchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawLeaderLinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawRichAnnoPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/GeomFormatPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CenterLinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CosmeticEdgePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CosmeticVertexPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTilePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTileWeldPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawWeldSymbolPy.cpp
Created file /home/tiedemate/freecad-build/doc/freecad.qch
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.13") found components: doxygen missing components: dot
-- Note: Doxygen docs will look better with graphviz's dot installed.
-- Coin3D doc is not installed
-- /home/tiedemate/freecad-build/src/Gui/DocumentPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/PythonWorkbenchPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderDocumentObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/WorkbenchPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/SelectionObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/LinkViewPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderLinkPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/AxisOriginPy.cpp
Summary report
-- Build type:
-- Compiler: /usr/bin/c++ (9.2.1)
-- Flags: -Wall -Wextra -Wno-write-strings
-- Python: [/usr/bin/python2.7] [-python2.7]
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 106700
-- XercesC: [/usr/lib/arm-linux-gnueabihf/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
-- PyCXX: [/home/tiedemate/freecad-source/src]
-- OCC: 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
-- SMESH: build internal
-- MEDFile: [/usr/lib/arm-linux-gnueabihf/libmedC.so] [/usr/include]
-- HDF5: 1.10.4
-- VTK: 7.1.1
-- NETGEN: not enabled
-- SWIG: 3.0.12
-- Eigen3 3.3.7
-- Qt4:
-- QtWebKit: found
-- Shiboken: 1.2.2 [/usr/include/shiboken]
-- PySide: 1.2.2 [/usr/include/PySide]
-- PySideTools: [/usr/bin/pyside-uic] [/usr/bin/pyside-rcc]
-- Freetype: 2.9.1
-- OpenGLU: /usr/lib/arm-linux-gnueabihf/libGLU.so [/usr/lib/arm-linux-gnueabihf/libGLU.so][/usr/include]
-- Coin3D: [/usr/lib/arm-linux-gnueabihf/libCoin.so] [/usr/include]
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib: not found
-- Rift: not enabled (BUILD_VR)
-- Doxygen: not found
Now run 'cmake --build /home/tiedemate/freecad-build' to build FreeCAD
-- Configuring done
-- Generating done
-- Build files have been written to: /home/tiedemate/freecad-build
I can't insert the output of the subsequent
make -j4
because it exceeds the character limit, so I attached it as a textfile.
Best regards!
Bjoern
