3D polyline with radii
Pauvres_honteux
Postby Pauvres_honteux » Mon Nov 25, 2019 11:28 am
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/default)
Version: 0.19.Unknown
Python version: 3.6.5
Qt version: 5.9.7
OCC version: 7.4.0
I could not find a function for creating a fully parametric 3D polyline where I can set the radius per node. The obvious "Draft wire" made a 3D polyline but did not change when I changed the points I first created.
Or did I search for elephants?
Polyline_Wire.FCStd
(7.67 KiB) Downloaded 14 times
Re: 3D polyline with radii
Postby chrisb » Mon Nov 25, 2019 12:59 pm
Why don't you use the Sketcher? There you can use constraints for such things.
Pauvres_honteux
Postby Pauvres_honteux » Mon Nov 25, 2019 1:15 pm
This topic headline says "3D polyline with radii". The Sketcher is 2D.
Catia Pipe with Polyline
Willem
Postby Willem » Mon Nov 25, 2019 1:36 pm
When all the radii are the same you can in the property box fill in a value for "Fillet radius"
Pauvres_honteux
Postby Pauvres_honteux » Tue Nov 26, 2019 8:04 am
Brilliant! And the radii are all in the right places. Then it's "just" a matter of making it possible to have different radii on each corner and following the points when one change them (parametric in my world).
Anyone against me creating a Feature Request about this?
Pauvres_honteux
Postby Pauvres_honteux » Tue Dec 03, 2019 3:51 am
Just came up with a "nice-to-have" feature for 3D-polyline: make it follow your surface of choice - Polyline on support.
In my world, internally, it should work in the same way as "Line on support", just in a coupled way.
Pauvres_honteux wrote:
Wed Oct 16, 2019 6:29 pm
in this picture no support were chosen.
GlouGlou
Postby GlouGlou » Tue Dec 03, 2019 6:04 pm
Option "polygonal" of InterpolationCurve (CurvWb) makes a parametric polyline. But doesn't have the radii feature. Maybe ask Chris to add that to interpolationCurve?
Pauvres_honteux
Postby Pauvres_honteux » Sat Jan 04, 2020 9:51 am
I've made a feature request for the 3D polyline with separate radii on each "corner", see: issue #4240
