Using the API
clel
Using the API
Postby clel » Tue Nov 26, 2019 1:12 pm
I am having problems finding functions used in scripts that I find here in the API on https://freecadweb.org/api/.
Example:
shape = Part.Shape()
shape.read(importPath)
mesh = Mesh.Mesh()
mesh.addFacets(shape.tessellate(0.01))
mesh.write(exportPath)
I did not find Part.Shape() in the API, neither did I find a read() function in Shape(), I also did not find Mesh.Mesh() and its corresponding functions.
I even had problems with this code from a recorded macro:
mesh = MeshPart.meshFromShape(Shape=shape,Fineness=0,SecondOrder=0,Optimize=1,AllowQuad=0)
Links to their occurence in the API are highly appreciated. I'd like to have some documentation for those functions.
DeepSOIC
Re: Using the API
Postby DeepSOIC » Tue Nov 26, 2019 3:16 pm
Hi!
I'm not sure if these are in the api. It seems pretty useless to me.
You should browse it in py console. First, "import Part". Then, type "Part.Sh" and you'll see a list of suggestions. As you scroll through the list, docstrings will pop up as tooltips.
clel
Re: Using the API
Postby clel » Tue Nov 26, 2019 3:59 pm
Ok, so the API available is rather incomplete then? Sad to hear that, it should maybe be mentioned on the API page.
So the only rather complete documentation is using the py console? This makes programming very hard. Thanks for the hint, though! It is probably very useful.
Re: Using the API
Postby wmayer » Tue Nov 26, 2019 4:04 pm
All of the mentioned functions are still available but you may have to first import the corresponding Python modules
import Part
import Mesh
import MeshPart
Re: Using the API
Postby Kunda1 » Tue Nov 26, 2019 4:32 pm
Browsing API from the Python console https://forum.freecadweb.org/viewtopic. ... 33#p272495
Please demonstrate using a remote text editor to substitute the Python editor in FreeCAD https://forum.freecadweb.org/viewtopic. ... 00#p346645
openBrain
Re: Using the API
Postby openBrain » Tue Nov 26, 2019 5:53 pm
As a side note to Kunda1's above post : https://forum.freecadweb.org/viewtopic. ... 70#p333170 ;)
vocx
Re: Using the API
Postby vocx » Wed Nov 27, 2019 9:28 am
This page is incomplete, https://freecadweb.org/api/.
Why? Because the entire Doxygen generated documentation is around 5 GB in size, and the developers didn't want to upload and host all that.
The best way to get the programming documentation is to get the source code and compile it yourself. See Source documentation and Doxygen.
Nevertheless, there is also the issue that many Python functions in FreeCAD are defined from the C++ sources but don't have a corresponding .py file. That is, something like Part.Shape is not defined in a Python file, but in a C++ class, and this is exposed in Python as Part.Shape. In order to fully understand how to use some functions you need to understand the C++ code, refer to the C++ sources and documentation, and in some cases to the OpenCASCADE Technology (OCCT) documentation.
DeepSOIC
Re: Using the API
Postby DeepSOIC » Wed Nov 27, 2019 9:37 am
Makes me wonder. It's not difficult to write a py script to auto browse all Part.something, gather all attributes, and generate a fake python module with all the classes having these methods with just docstrings. Then feed it to doxygen...
looo
Re: Using the API
Postby looo » Wed Nov 27, 2019 10:06 am
Thinking about fake-python modules / abstraction layers, why not combine ideas and use the freecad namespace to put this all into?
But if we ever do anything in this direction, I guess we first need to define policies for the API which includes (Gui vs App handling, naming conventions, import-conventions, ...)
minimalistic blog: https://looooo.github.io/mini-blog/
vocx
Re: Using the API
Postby vocx » Wed Nov 27, 2019 4:42 pm
Makes me wonder. It's not difficult ...
Are you asking, or are you saying this as a matter of fact? I think it is hard, and that's exactly why it hasn't been done before.
Yorik has mentioned it a few times, that in the past they thought about creating fake Python files with the information, and then documenting this with Sphinx, but it wasn't as straight forward. His attempts are in src/Doc/sphinx.
I would think it's hard to do this, but that's just my impression, I don't understand exactly how the whole wrapping of C++ classes works in FreeCAD. It would be great if there was a complete explanation by Werner or you or somebody who really knows.
