Ticket #4206 - Transparency display lost on multicolored object when reloading file
otoien
Post by otoien »
After saving a file, next time it is reloaded I keep having trouble that display of transparency frequently is lost on more complicated objects but not the transparency parameter. Initially I thought this had to do with objects originally imported from STEP files (where after transparency was set), however I have now been able to isolate a the simple case of an extruded object with multicolored faces where transparency display is lost on file load.
To reproduce (tested with latest development version on Win7, but I have experienced these problems for a long time, also in stable ver. 0.18):
1. Create a simple shape, for instance a rectangle and extrude it. Mark it and apply transparency under the view tab, for instance set it to 80% and observe correct display. Save and close file. Reload it and observe correct display of transparency.
2a. Mark object, right click, Set Colors, mark one of the faces and change color. Keep transparency. Transparency is still corretly displayed. Save file and close it. Reload file. Observe transparency display gone but color is correct, and on inspection the transparency parameter under the view tab is still at 80%.
2b. Close file without saving and reload again (transparency gone). Mark object and change color so that it gets a single color. Transparency is back again. Save file, close and reload. Transparency is now correct.
2c. Close file without saving and reload again (transparency gone). Change transparency (for instance to 81%). Observe correct transparency being displayed again. Save, close and reload. Transparency display is gone again.
Is this a bug, or an inherent "feature"? It would seem that because a simple thing as making a change to the transparency parameter can make it appear again, a routine that would bring back transparency display could be performed on file load?
Could the problems be related to this fairly recent change that can allow per face transparency to be set?
https://forum.freecadweb.org/viewtopic.php?t=16476
The attached files show the results of the different tests above.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18760 (Git)
Hash: ef73ab5f3a330d3c44138f23290f8c9f7a334caf
Python version: 3.6.7
Qt version: 5.12.1
(For the record I am using a Nivida graphics card)
2a:
Transparency-test001a.FCStd
(5.34 KiB) Downloaded 56 times
2b:
Transparency-test001b.FCStd
2c:
Transparency-test001c.FCStd
(5.33 KiB) Downloaded 55 times
Reason: Added ticket number to thread title
otoien
Re: Transparency display lost on multicolored object when reloading file
Post by otoien »
A little bump as it got off the screen too fast:
Can anyone reproduce this with the attached files or described procedure?
Should it be reported on the bugtracker?
UR_
Post by UR_ »
Same here
OS: Windows 10 (10.0)
Version: 0.19.18782 (Git)
Hash: 84752715e829ed7fec40453a0714513b36d637a9
Python version: 3.7.3
Qt version: 5.12.5
OpenGL version is: 4.6 (4.6.0 NVIDIA 441.20)
for 2 faces compound , property tab says:
Screenshot 001.png (4 KiB) Viewed 2436 times
but console prints:
obj.ViewObject.DiffuseColor
[(0.0, 0.0, 1.0, 0.0), (0.800000011920929, 0.800000011920929, 0.800000011920929, 0.0)]
Post by wmayer »
Confirmed! Feel free to open a bug report.
The problem might be that the Transparency property was designed to affect the whole object and the possibility to set transparent color per face was added much later. So, it seems that the order of reading in the properties from the project matters.
otoien
Post by otoien »
Thanks, bug report submitted: issue #4206
Reason: Replace url tags with bug tags
sgrogan
Post by sgrogan »
otoien wrote: Tue Nov 26, 2019 9:57 pm Thanks, bug report submitted: https://www.freecadweb.org/tracker/view.php?id=4206
Thanks otoien!
This is a model bug triage/bug report for FreeCAD.
"fight the good fight"
Montoya88
Re: Ticket #4206 - Transparency display lost on multicolored object when reloading file
Post by Montoya88 »
Hi, I'm having transparency issues myself. However when I adjust transparency to anything other than 0 all objects turn to wire frame.
And your version is ...?
Montoya88
Post by Montoya88 »
OS: Windows 8.1
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Montoya88
Post by Montoya88 »
Attached is the file that I attempted to use transparency. Mainly the objects named sleeve and sleeve splice
Goal Post.FCStd
(135.89 KiB) Downloaded 58 times
