Dedicated Spreadsheet Workbench Maintainer/Devs needed
Postby Kunda1 » Sat Nov 09, 2019 1:04 pm
Anyone interested in helping to maintain/develop/fix/triage the Spreadsheet Workbench. It is getting to be a pretty popular part of users FC workflow and there is a backlog of bugs and feature requests:
issue #4197 - Crash on Recompute With Expression as PropertyString Value
issue #4196 - Expression parser does not allow "/" after first member
issue #4192 - Set an expression with many objects at the same time
issue #4191 - Freecad 0.19pre crashes in spreadsheet
issue #4003 - Renaming spreadsheet no longer has any affect on field tags.
issue #4037 - rewrite unit handling so that unit prefixes will be recognized
issue #4031 - Crash upon solving expression referencing named Constraint
issue #4015 - Expression "jumps" to new object when created
issue #3981 - Add Expression support to certain fields
issue #3925 - Negative numbers with multiple units interpeted as expressions
issue #3839 - Support to update sketch when changing values in a spreadsheet
issue #3696 - Constraints lose values upon reloading file.
issue #3518 - Expressions (fx) not updated
issue #3487 - Add ability to copy objects with expressions linked to spreadsheet
issue #3466 - Control objects visibility via expressions and spreadsheets cells
issue #3460 - Add the following functions to expressions and spreadsheet: concatenate text and indirect
issue #3448 - Failed to parse expression
issue #3391 - Array and dictionary lookup does not work in expressions
issue #3379 - Certain identifiers (like h, rad) cannot be used as names for constraints for usage in expressions
issue #3272 - Failed to parse expression occurs when referencing an alias in an external spreadsheet document
issue #3271 - Relative file references give 'Document not found' unless that file is opened first
issue #3255 - Use consistent angle measure for expressions
issue #2957 - please add spreadsheet direct printing
issue #2766 - Expression link is cuting by creating new object
issue #2477 - Copy of sub objects with expression pointing to a spreadsheet shall not create a new spreadsheet
issue #2474 - Integrate LibreOffice Calc via GUI
issue #2472 - Spreadsheet - Move Cells
issue #2467 - Expression auto-completer slows down FreeCAD
issue #2100 - Spreadsheet: Additional Inverse Display Units
Also, there is a need for better scripting documentation of the Spreadsheet Workbench#Scripting Basics
Re: Dedicated Spreadsheet Workbench Maintainer/Devs needed
Postby Kunda1 » Fri Nov 15, 2019 12:57 pm
anyone ?
Joel_graff
Postby Joel_graff » Fri Nov 15, 2019 4:35 pm
I'm definitely interested in seeing improvement here.
Setting up FC for dev on my machine has always been problematic, so I don't know that I can contribute directly. However, I think both improving the Spreadsheet module and LO integration would be great GSOC projects - especially LO Calc.
Maybe we could at least identify a path for getting LO integration to work? I have a few of the details worked out, but really no idea. Would happily mentor a GSocC student next year, though. :)
vocx
Postby vocx » Fri Nov 15, 2019 4:58 pm
... LO integration would be great GSOC projects - especially LO Calc.
What is LO?
kkremitzki
Postby kkremitzki » Fri Nov 15, 2019 5:38 pm
vocx
Postby vocx » Fri Nov 15, 2019 7:36 pm
https://www.libreoffice.org/
Oh. I just hate the use of too many acronyms.
triplus
Postby triplus » Fri Nov 15, 2019 8:58 pm
In my opinion we won't "Integrate LibreOffice Calc via GUI" into Spreadsheet workbench anytime soon, as that is just (technically) unrealistic. Best to close the issue as "won't fix".
ulrich1a
Postby ulrich1a » Fri Nov 15, 2019 9:21 pm
I agree to this statement. The spreadsheet in FreeCAD handles objects like properties of shapes where no counterparts exist in LibreOffice.
Ulrich
Postby Kunda1 » Fri Nov 29, 2019 1:10 pm
Anyone willing to step-up and fix these bugs before 0.19 release?
ezzieyguywuf
Postby ezzieyguywuf » Fri Nov 29, 2019 1:35 pm
I can take a look. I’ll put a pause on my other freecad projects for a few days and try to wrap my head around these spreadsheet improvements.
