freecadweb.org
sgrogan
freecadweb.org
Postby sgrogan » Sun Dec 08, 2019 2:47 pm
After this commit: https://github.com/FreeCAD/FreeCAD-Home ... 3f6699ecc2 the whole freecadweb.org seems quite broken
Anyone else experiencing this?
EDIT: See here also: https://forum.freecadweb.org/viewtopic. ... 06#p352632
openBrain
Re: freecadweb.org
Postby openBrain » Sun Dec 08, 2019 2:51 pm
Don't know if related to this commit, but here with a mobile, wiki seems unreachable and CSS of forum is broken (Tools menu is unfolded and inlined in the page). ;)
alonso_jamm
Re: freecadweb.org
Postby alonso_jamm » Sun Dec 08, 2019 4:01 pm
I also have problems with loading CSS in the forum and getting 404 errors in the wiki. And when I try to go to www.freecadweb.org I only get a blank page. I have tried with both desktop and mobile.
ezzieyguywuf
Re: freecadweb.org
Postby ezzieyguywuf » Sun Dec 08, 2019 5:40 pm
I have had intermittent issues on my desktop.
openBrain
Re: freecadweb.org
Postby openBrain » Sun Dec 08, 2019 5:44 pm
Mantis tracker is severely impacted too. ;)
kkremitzki
Re: freecadweb.org
Postby kkremitzki » Sun Dec 08, 2019 6:47 pm
Fixing this shortly.
sgrogan
Re: freecadweb.org
Postby sgrogan » Sun Dec 08, 2019 6:48 pm
Thanks! Sorry for the crap show :oops:
kkremitzki
Re: freecadweb.org
Postby kkremitzki » Sun Dec 08, 2019 7:00 pm
It was actually my fault as I left the bad Travis config which caused it originally in the repo after fixing it the last time so it was just a matter of whoever committed to the repo next. I fixed that and so now everything should hopefully be back to normal.
sgrogan
Re: freecadweb.org
Postby sgrogan » Sun Dec 08, 2019 7:03 pm
Thanks. Would it be better if in the future I just make a pull request? I was trying to save you work not make new work :(
kkremitzki
Re: freecadweb.org
Postby kkremitzki » Sun Dec 08, 2019 7:11 pm
Unfortunately so, until we get an automated way to deploy, since changes will still have to be uploaded manually.
For the record I did some investigation on this and our hosting provider only supports FTP secured with SSL on port 21, not SFTP on port 22, which is the exact opposite of what Travis supports, so until we migrate from shared hosting to a VPS, it will have to be manual. (Unless we were to try a different CI provider which may not work either.) I have a plan to migrate the bug tracker to a VPS first as an experiment, I just need Werner or Yorik to add a DNS A record pointing tracker.freecadweb.org to 104.248.47.186 (a server in DigitalOcean's Frankfurt datacenter) as I don't think I have DNS access for the freecadweb.org domain. With this plan, existing freecadweb.org/tracker/... links will work but redirect to the same resource on tracker.freecadweb.org/...
