[fixed] hatch in cross section view get broken on SVG exporting
uwestoehr
Postby uwestoehr » Mon Dec 09, 2019 6:43 pm
- open this test file:
TD-test.FCStd
test file
(129.56 KiB) Downloaded 15 times
(Note, that despite both section views were created, only section A-A has a hatch
This is in my opinion also a bug.)
- export it as SVG
- open the SVG with Firefox or Inkscape (my result is attached)
result: the hatch is too large
Edit: when exporting to PDF, the hatch is correct
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18859 (Git)
Hash: 42196ead3902cef974e2c3ed7810a7c69258ea89
Python version: 3.6.8
Qt version: 5.12.1
TD-test.svg
SVG result
(299.72 KiB) Downloaded 14 times
wandererfan
Re: hatch in cross section view get broken on SVG exporting
Postby wandererfan » Tue Dec 10, 2019 12:01 am
- export it as SVG
"Note that SVG hatch patterns are not included when a drawing page is saved as an SVG file."
The export routine doesn't deal with hatches at all well. Had hoped that Qt5 would improve things, but apparently not. In the Svg file does the A-A hatch pattern extend beyond the figure? That is supposed to be turned off.
definitely something wrong with the B-B section face. Haven't seen this particular error before.
uwestoehr
Postby uwestoehr » Tue Dec 10, 2019 12:24 am
But the hatches are exported to SVG. They only extend beyond the view, see the SVG file in my initial comment.
I can reproduce this on my Win 7 PC as well:
- take my example file
- delete the section view B-B
- select the view "Left"
- insert a section view to it
- in the appearing task dialog click on "looking left"
result: you get a section view without hatch
wandererfan
Postby wandererfan » Tue Dec 10, 2019 11:58 am
Hmmm. The hatches were hidden on Svg export for just this reason. The hatch pattern doesn't get clipped. Don't remember removing this code.
wandererfan
Postby wandererfan » Tue Dec 17, 2019 1:45 pm
Regression on Svg hatch export should be fixed by: git commit 57bfc2e380
uwestoehr
Postby uwestoehr » Wed Dec 18, 2019 11:40 am
Thank you!
I tested and unfortunately, this is not fixed. Here is the result:
TD-test.svg
SVG output
(299.72 KiB) Downloaded 13 times
I get with:
OS: Windows 10 (10.0)
Version: 0.19.18986 (Git)
Hash: 537620aa32244287055d6ab312b0f8eaa5407fc9
Qt version: 5.12.1
regards Uwe
wandererfan
Postby wandererfan » Wed Dec 18, 2019 12:17 pm
I tested and unfortunately, this is not fixed. Here is the result: TD-test.svg
Awww, #@#$%!!@$%. Forgot section faces. :oops:
Fixed for regular views. Sections to follow.
robin.jonsson.4276
Postby robin.jonsson.4276 » Mon Jan 13, 2020 4:42 pm
Hi, Is section view hatch on the way?
Or could you mention a temporally work around?
(I'm exporting as pdf right know but that means lost of quality when I import it in LibreOffice writer.)
Thanks
wandererfan
Postby wandererfan » Mon Jan 13, 2020 6:15 pm
Svg export of Svg hatch patterns will likely never be available as the problem is in code we don't own. Svg export of Pat hatch patterns (GeometricHatch) works fine.
