Waterline milling update
Giulio Buccini
Re: Waterline milling update
Post by Giulio Buccini »
Hello everybody,
just a question: so, at the moment, there is no way to mill a conical surface with the Path workbench, I'm right? :?
(Apart from manually generating dozens of sections, and then milling them one by one.)
BTW: the waterline algorithm will be included in the next 0.19 version?
sliptonic
Post by sliptonic »
You can get pretty close with a 3D pocket.
Choose the offset pattern
RatonLaveur
Post by RatonLaveur »
Today I was running waterline on a positive half sphere and ran into a pretty difficult issue.
The Layered option works well, unfortunately it means the step-over isn't constant. This leads into an issue with the finish.
Is it possible that the waterline milling might have an option to keep stepover constant?
You can very well use Path 3DPocket:
Snip macro screenshot-2e5f67.png (51.72 KiB) Viewed 1628 times
conePath.FCStd
(74.33 KiB) Downloaded 57 times
Giulio Buccini
3D Pocket doesn't work for me.
It mills inside the cone also...
Countersunk-Washer M6-3D_milling_test.FCStd
(28.56 KiB) Downloaded 46 times
Please make sure that you use the latest 0.19 and add your FreeCAD infos.
I can confirm the inside path. It could be avoided if finals depth was editable.
For a workaround you are lucky that we have discussed this recently and I made several tests: You can use a Boundary dress-up:
Snip macro screenshot-89a259.png (38.8 KiB) Viewed 1609 times
Besides I used KeepToolDown to tidy the paths.
Countersunk-Washer M6-3D_milling_cb.FCStd
(28.3 KiB) Downloaded 52 times
Giulio Buccini
chrisb wrote: Wed Dec 11, 2019 10:55 pm Please make sure that you use the latest 0.19 and add your FreeCAD infos.
Is the 0.19 available???
My version:
OS: Ubuntu 16.04.6 LTS
Version: 0.18.4.
Python version: 2.7.12
Giulio Buccini
chrisb wrote: Wed Dec 11, 2019 11:20 pm I can confirm the inside path. It could be avoided if finals depth was editable.
I cannot find any "Boundary dress-up" in Path menu of my 0.18.4 version. All I see are the usual "Dogbone dressup", "Tag dressup", etc.
I'm missing something? :?
Giulio Buccini wrote: Wed Dec 11, 2019 11:46 pm I cannot find any "Boundary dress-up" in Path menu of my 0.18.4 version. All I see are the usual "Dogbone dressup", "Tag dressup", etc.
It's only in 0.19: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
