Turro75
Postby Turro75 » Wed Dec 18, 2019 9:42 pm
Hi @Kbwbe!
I'm facing a quite slower importing of complex shapes, I wonder if multithreading the conversion from shape to shell could speed up that process or, as alternative approach, the rewriting of those functions as C code.
What do You think about?
Valerio
kbwbe
Postby kbwbe » Thu Dec 19, 2019 7:50 am
Hi Turro,
there should be no changes in master branch which have slowed down the imports. Do you register that importing got slower or are you importing bigger shapes bigger than before ?
> Multiprocessing/Multithreading: May be better, i have to check how good this works with FC.
> C-code: Sure faster, but i have no idea about implementing it into FC.
Additional:
I am working on a big update within the devel branch. A2plus creates "xxx.a2p" files during importing of files. The files contain all resulting work of an import process (shape, colours, toponames) and speed up a second time import by factor 3-4.
KBWBE
latest release: v0.4.48, installable via FreeCAD's addon manager
Turro75
Postby Turro75 » Thu Dec 19, 2019 5:29 pm
Hi Turro,
Additional:
Hi Kbwbe,
Yes I'm talking about complex objects with many curved surfaces which creates tons of faces.
by analyzing a2p_muxassembly.py it looks like the slowness is mainly caused by Part.Makeshell(faces), other iterations look such as creating the faces list so I don't expect a big improvement in parallelizing them. Am I wrong?
Regarding C code.... rewriting the workbench in C IMHO requires too much work compared to the benefit, it would be interesting writing complex calculation task in a .dll and .so and importing it in python, it could be helpful in replacing some numpy or placement complex iterations within the solver (if any).
threading across cores is quite easy in python, from https://docs.python.org/3/library/multiprocessing.html
from multiprocessing import Pool
def f(x):
    return x*x
if __name__ == '__main__':
    with Pool(5) as p:
        print(p.map(f, [1, 2, 3]))
kbwbe
Postby kbwbe » Sun Dec 22, 2019 12:37 pm
Hi Turro,
I am not quit sure, but Part.Makeshell(faces) cannot be parallelized, as OCC is only using one core/process. Please tell me if i am wrong.
Yes...
1) I do not have any experience in interfacing python with C/C++, that's my problem
2) The ".dll" and ".so" files would have to be compiled for each OS, probably by the user. Using pure python is much more easy for many users.
I know, i have been working with that on other projects.
Are you using the toponaming option of A2plus? Using this needs some computation time.
KBWBE
kbwbe
Postby kbwbe » Sun Dec 22, 2019 12:55 pm
Hi people,
A2plus V0.4.33 has a new feature (thanks to a user request). Now you can click a part and move it around under rule of all constraints.
Have a look at this video:
phpBB [video]
Have fun.
Merry christmas to all,
Klaus
P.S: Find the assembly attached (for your own experiments)
asm-viergelenk.FCStd
(21 KiB) Downloaded 35 times
KBWBE
Christoph
Postby Christoph » Sun Dec 22, 2019 2:40 pm
Hi people,
I'm impressed, thank you very much creating this feature!
dan-miel
Postby dan-miel » Sun Dec 22, 2019 5:48 pm
kbwbe:
I haven't tried this yet but it is something that I wanted to ask for but, again a but, the animations were so slow I never dreamed that this would be possible. Fantastic!
Dan
roerich_64
Postby roerich_64 » Sun Dec 22, 2019 6:38 pm
Hi Klaus,
Also from me: thank you for the new future:-)
Have a nice Christmas with your family and a happy new year:
Bests
Walter
uwestoehr
Postby uwestoehr » Mon Dec 23, 2019 12:35 am
Documented: A2plus_Workbench#Dragging
A2p_example-for-dragging-animation.FCStd
(20.04 KiB) Downloaded 929 times
kbwbe
Postby kbwbe » Fri Dec 27, 2019 7:26 pm
A2plus function "importPart" has been broken today for a short time on master branch. Please update to new version V0.4.34a
Sorry!
KBWBE
