Union of three bodies fails
Hi everyone
I tried to make an union of three bodies. One central is a clone of a model cube, the two others are clones of a model half cylindre.
I create my three clones, add a translation on x on the first half cylindre, a rotation around y and an opposed translation on x on the second half cylindre. I see correctly my three bodies, joined in the final position that I want. I then ask the creation of a new body, with a boolean union function, select the three clones... up to there everything is smooth and OK. Then I click on the "OK" button of the boolean union and, upon it's exit, I see only the last two selected bodies of the union.
Do I miss something, or is there a known problem in such an operation ?
OS: Windows 10 (10.0)
Version: 0.19.19311 (Git)
Hash: 120b69c74f7dac8c4fa6dbc0a7e10674bde9216c
Python version: 3.7.3
Qt version: 5.12.5
Locale: French/France (fr_FR)
Qt version: 5.12.5
Re: Union of three bodies fails
A boolean in a PartDesign body is different from a boolean in Part: Like all other features it adds/subtracts from the solid created so far. As you don't have a solid if the boolean is the first item in the body, fancy things can happen.
PartDesign Booleans are not really a replacement for Part Booleans. If you want those, take them from Part workbench.
In your case you should simply model it all in one body.
IIRC it has already been reported that Union bugs with 3 objects. I'll try to find a link.
What I present in this simple example is a simplification of a complex model, reduced to show where the problem arises. I can't design this in just one body.chrisb wrote: ↑Fri Jan 24, 2020 1:59 pm A boolean in a PartDesign body is different from a boolean in Part: Like all other features it adds/subtracts from the solid created so far. As you don't have a solid if the boolean is the first item in the body, fancy things can happen.
But you can always use bodies which do not start with a boolean.
Was in your mother language JiPe38 : https://forum.freecadweb.org/viewtopic. ... 20#p358024
But I guess this deserves a dedicated discussion. So let's go for it. I'll confirm later when I have a PC if nobody did in between.
A minimalist example would also be welcome.
Not a lot to do with current discussion. The one you pointed talks about boolean operations of PartDesign.Roy_043 wrote: ↑Fri Jan 24, 2020 7:11 pm This discussion?:
https://forum.freecadweb.org/viewtopic.php?f=8&t=41910
That's exactly what OP talks about:
with partdesign the worflow is different of part.
active one body, then call the boolean feature then select the other bodies.
theses two bodies will embedded inside the first one.
- threeBodyUnion.FCStd
- (31.74 KiB) Downloaded 14 times
