[Bug#4342] 0.19pre grouped buttons conflict in customized toolbar
Moderator: agryson
fc_tofu
Postby fc_tofu » Mon Jan 27, 2020 10:27 am
version: FreeCAD_0.19.19358_x64_Conda_Py3QT5-WinVS2015
OS: Win10 x64
My first time to use toolbar customize funtion. I dupliated PartWB toolbars into DraftWB.
Before restarting FreeCAD, everything works ok.
But after restarting FreeCAD, grouped buttons dont display name and dont work when pressed, on both DraftWB and PartWB sides.
Reproduce:
1. Restart FreeCAD, and switch to DraftWB.
2. menu >Tools >Customize >Toolbars.
3. on right pane, add a toolbar named "Draft Custom" (for example).
4. on left pane, find "Part >Compound Tools" (this is a tool group).
5. add "Compound Tools" to "Draft Custom".
6. Close "Customize" and restart FreeCAD.
7. Obsever "Compound Tools" on DraftWB and PartWB toolbars.
Before customize:
Customize:
After customize:
Tracker (20200515 submitted)
issue #4342
fc_tofu
Re: 0.19pre grouped buttons conflict in customized toolbar
Postby fc_tofu » Mon Jan 27, 2020 10:29 am
It seems Pasteboard doesnot support external ref. And I turn to Imgur.
Postby chrisb » Mon Jan 27, 2020 12:38 pm
You can attach images directly to a post. That makes it much easier to compare the before/after states.
fc_tofu
Postby fc_tofu » Mon Jan 27, 2020 1:22 pm
Thanks, I got it.
DeepSOIC
Postby DeepSOIC » Mon Jan 27, 2020 1:38 pm
hmm, that's odd...
fc_tofu
Postby fc_tofu » Wed May 13, 2020 5:19 pm
Bug still in latest build.
OS: Windows 10 (10.0)
Version: 0.19.20943 (Git)
Hash: ceb23799c76df3ebfa7be4b9fe83bb62de60bc6c
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
fc_tofu
Re: [Bug#4342] 0.19pre grouped buttons conflict in customized toolbar
Postby fc_tofu » Fri May 22, 2020 2:52 pm
Furter tests.
3 button-groups is related to this bug, all from PartWB. They are:
Compound tools, Join objects, Split objects.
Other button-groups are not affected, such as:
DraftWB >Arch tools/Bezier tools/Array tools
PartWB >Offset
PartDesignWB >Create additive/Create subtractive
When related button-group is customized to DraftWB and TechDraw, button conflict issue appear.
This bug happen to latest 0.19pre build and 0.18.4/Win10x64.
Some workbenches seem not affected by this bug. But here need more tests to prove that.
To see the behavior of button confilct, restart of FC is must.
Attachment is my "user.cfg", made in a newly installed 0.19pre. Only changes are above mentioned button-groups customized to DraftWB/PartWB/PartDesign/TechDraw.
Version: 0.19.21097 (Git)
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
user.zip
(6.19 KiB) Downloaded 1 time
