Curves workbench
freecad-heini-1
Re: Curves workbench
Postby freecad-heini-1 » Tue Jan 28, 2020 6:34 pm
Chris_G wrote:
Tue Jan 28, 2020 5:33 pm
I added a new tool : Multi-Loft
The goal is to loft "multi-face" objects like shapestrings.
Please upload your Freecad example file.
Chris_G
Postby Chris_G » Tue Jan 28, 2020 6:53 pm
multiloft.FCStd
(89.95 KiB) Downloaded 32 times
Chris_G
Postby Chris_G » Tue Jan 28, 2020 10:24 pm
chrisb wrote:
Tue Jan 28, 2020 6:30 pm
I have more and more the feeling that this workbench should be part of core FreeCAD!
Thanks Chris, that's very kind of you.
The whole WB is not worth going to core FC, of course, but I see it as a sandbox, in order to test and see if some tools deserve going to core FC.
My big goal would be to add Gordon surfaces, as it is an important low-level algorithm.
But I'm not there yet.
However, I would be curious to hear opinions about which CurveWB tools would deserve going to core FC.
I have the feeling that JoinCurves, and BlendCurves are appreciated.
Postby chrisb » Tue Jan 28, 2020 11:17 pm
There are many great workbenches out there doing phantastic things. But as much as I like and use them I think that Curves is something special: It provides rather basic CAD functions which are not possible otherwise.
Asking for tools which should go into core FreeCAD: the two rail sweep comes immediately to mind.
drmacro
Postby drmacro » Wed Jan 29, 2020 8:48 pm
Um...I'm doing something wrong...I get a bunch of points. :?
Edit: never mind. I see I should've used the Draft WB > Clone tool.
Shapestring_along_path-2.FCStd
(57.73 KiB) Downloaded 7 times
freecad-heini-1
Postby freecad-heini-1 » Wed Jan 29, 2020 9:18 pm
Please check my Freecad File.
Via placement you can change the position of the cloned shapestring.
Shapestring_along_path-2_fh-1_V2.FCStd
(69.63 KiB) Downloaded 6 times
drmacro
Postby drmacro » Thu Jan 30, 2020 1:20 pm
Yes, I knew how to move the clones, but, as noted it doesnt seem to work for clones created with Part Design WB that end up in separate bodies. the Multiloft node on the tree shows an error: Shape is not a shell. (Same shapestring (same font, etc.) work using the Clone tool on the Draft or Curves WB.
I chose a arc for simple experimentation. So, setting the angle with position works in this example. But, would like to follow an arbitrary curve though... :?:
freecad-heini-1
Postby freecad-heini-1 » Thu Jan 30, 2020 1:50 pm
It's a cool new feature for multi loft, not sweep. ;)
Chris_G
Postby Chris_G » Thu Jan 30, 2020 2:20 pm
There was a bug with the placement of PartDesign objects.
It should be fixed now (finger crossed :mrgreen: )
drmacro
Postby drmacro » Thu Jan 30, 2020 3:04 pm
That does appear to have fixed it with Part Design objects. :)
