_THE_ main issue of FreeCAD is toponaming. However for now one has to live with it, also for TD. In order to do this, TD must allow to remove broken dimensions but does not yet.
Take for example this test file:
You see there dimensions like "0.000" since I changed something in the construction and used afterwards the menu TechDraw -> Redraw Page.
- directly after opening perform TechDraw -> Redraw Page
You will get the info that some dimensions are broken. The quickest way is to remove them and re-add the ones you need.
- therefore select in the page (not in the tree) in the Front view the dimension "0.000" and press the DEL key on your keyboard
result: -> you get this warning:
But why should the page break just because of removing a dimension? So TD should be robust enough that the page and template stays stable and only the dimension is removed and such a warning dialog is not necessary.
