FreeCAD and ParaView
HarryvL
Re: FreeCAD and ParaView
Postby HarryvL » Sun Feb 09, 2020 3:28 pm
I finally got around to writing a tutorial (work in progress):
https://www.freecadweb.org/wiki/Post-Pr ... h_Paraview
And here is the FreeCAD model used for the Tutorial:
Concrete_Beam_Central_Support.FCStd
(510.78 KiB) Downloaded 199 times
Postby bernd » Sun Feb 09, 2020 7:25 pm
harry this will help me a lot! I really need this but never have the time to lern all this in paraview myself. Very well done!
cheers bernd
Will you do the integral stuff as well?
HarryvL
Postby HarryvL » Sun Feb 09, 2020 7:44 pm
cheers bernd
Hi Bernd, integration over the full VTK object is already covered. I will also cover integration over a slice (to show how to reinforce a cross section of a beam) and integration over a line (to show how to reinforce a wall). However, for the the last one I want to use a 2D case (most likely the CIB example).
I still want to do an example of reinforcing a massive concrete structure and how to treat that with FC and PV, but that will come later. It would be nice to have a practical design case to work with. Do you have one from your day job?
-alex-
Postby -alex- » Sun Feb 09, 2020 7:50 pm
I'm gona learn about Paraview with this tutorial, thank you Harry :D
HarryvL
Postby HarryvL » Sun Feb 09, 2020 7:57 pm
De rien Alex
HarryvL
Postby HarryvL » Sun Feb 09, 2020 8:00 pm
cheers bernd
I mean FIB, not CIB :roll:
Postby bernd » Mon Feb 10, 2020 8:15 am
what kind of structure? A beam, a wall, a slab, a foundation, a column?
HarryvL
Postby HarryvL » Tue Feb 11, 2020 8:29 am
Something bulky (truly 3D) so a foundation, I guess.
HarryvL
Postby HarryvL » Tue Feb 11, 2020 10:45 pm
I have updated the Tutorial with two sections, one about integration over a slice and the other about visualization and integration along a line.
The latter section uses the following example:
FIB_wall.FCStd
(479.47 KiB) Downloaded 54 times
HoWil
Postby HoWil » Wed Feb 12, 2020 3:45 pm
Quite comprehensive tutorial.
Well done.
