Again i have a mysterious problem: If i try to save a Job as gcode file i get this error message:
Running the Python command 'Path_Post' failed:
File "/tmp/.mount_FreeCA3VISoT/usr/Mod/Path/PathScripts/PathPost.py", line 390, in Activated
(fail, rc) = self.exportObjectsWith(finalpostlist, job)
File "/tmp/.mount_FreeCA3VISoT/usr/Mod/Path/PathScripts/PathPost.py", line 212, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "/tmp/.mount_FreeCA3VISoT/usr/Mod/Path/PathScripts/PathPostProcessor.py", line 102, in export
return self.script.export(obj, filename, args)
File "/tmp/.mount_FreeCA3VISoT/usr/Mod/Path/PathScripts/post/linuxcnc_post.py", line 189, in export
job = PathUtils.findParentJob(obj)
File "/tmp/.mount_FreeCA3VISoT/usr/Mod/Path/PathScripts/PathUtils.py", line 397, in findParentJob
if hasattr(i, 'Proxy') and isinstance(i.Proxy, PathScripts.PathJob.ObjectJob):
Cannot access attribute 'Proxy' of deleted object
I have had this problem at 2 different files with similar parts. The fault appers if i make the whole work from path creation to "export to gcode" at on session.
One of the files where i get the prob with is attached, but i think it's not helpfull, because ofter the new start of FC the export works each time i try...
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.19541 (Git) AppImage
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
