libnglib not found at runtime
rynn
Postby rynn » Fri Feb 14, 2020 6:16 pm
Hello,
I have the problem that libnglib is not found by the mesh-workbench at runtime. CMake finds netgen and it compiles fine.
vocx
Re: libnglib not found at runtime
Postby vocx » Fri Feb 14, 2020 7:16 pm
Hello,
Important information
Postby wmayer » Fri Feb 14, 2020 7:31 pm
Hello,
Most likely the issue is that libnglib.so is located in a directory that is not listed in ld.so.conf. For example, often it is installed under /opt.
To solve the issue you have two possibilities:
* set the environment variable LD_LIBRARY_PATH pointing to the directory where the library is located
* add an entry to /etc/ld.so.conf and update the cache
See:
http://archive.linuxfromscratch.org/lfs ... x2141.html
http://man7.org/linux/man-pages/man8/ldconfig.8.html
reox
Postby reox » Fri Feb 14, 2020 7:42 pm
Are you running debian?
I reported that already: https://bugs.debian.org/cgi-bin/bugrepo ... bug=924300
rynn
Postby rynn » Sun Feb 16, 2020 7:01 pm
Yes. That’s the problem. But I’m not sure the Problem is on the debian side...
reox
Postby reox » Sun Feb 16, 2020 7:26 pm
I would say so, as debian configures where to put the header files.
But if you have any other information please put them into the bugreport :)
