Part Design: problems with Thickness tool
koluna
Postby koluna » Fri Feb 28, 2020 4:09 pm
Hi, Dears!
OS: Linux Mint 18.1 Serena (MATE/mate)
Version: 0.19.
Python version: 3.5.2
I have taken an Additive Cylinder.
I have applied a Thickness tool to it.
It works.
But there are some intersections in the Body... Is it true? Why?
Or, are there some troubles with normals?
I have exported my Body to STL and opened it in Blender. And I have seen some problems... Why?
test.FCStd
(64.84 KiB) Downloaded 9 times
uwestoehr
Re: Part Design: problems with Thickness tool
Postby uwestoehr » Sat Feb 29, 2020 2:44 am
The interesting question is how you created the STL. Here is an STL I created using your model:
case (Meshed).stl
STL mesh result
(114.05 KiB) Downloaded 1 time
It works fine for my 3D printer. I don't have Blender and did not understand what your problem is with it.
From the PartDesign point of view, your model looks good.
koluna
Postby koluna » Sat Feb 29, 2020 10:01 am
File -> Export.
Here is an STL I created using your model: case (Meshed).stl
Your model behaves like mine.
I have printed it. It was fine.
See a picture below...
Why are triangles at the picture (Transparency property is 50%)?
koluna
Postby koluna » Sat Feb 29, 2020 10:17 am
See the file test2.
test2.FCStd
(14.73 KiB) Downloaded 2 times
kisolre
Postby kisolre » Sat Feb 29, 2020 10:30 am
Probably just some display artifacts. Onscreen everything is actualy triangles...
koluna
Postby koluna » Sat Feb 29, 2020 11:25 am
I am trying to understand: are these artifacts normal?
Hmmm... a strange behavior in Blender is not all time...
The models were imported with a 1000 scale... when I had scaled them to 0.001 the Blender view has become fine!
uwestoehr
Postby uwestoehr » Sat Feb 29, 2020 4:55 pm
These are just display artifacts. They occur with certain settings. For me it often helps to use e.g. 51% transparency or to to try out if in the preferences -> Display the option "Use OpenGLo VBO" improves the situation.
Concerning the STL creation, you should do this via the Mesh workbench because then you can control the mesh deviation from the original model and thus also potential display issues in other programs like Blender.
koluna
Postby koluna » Tue Mar 03, 2020 6:39 am
Thanks a lot! I know it now :)
Which? I did not understand...
uwestoehr
Postby uwestoehr » Tue Mar 03, 2020 10:36 am
Now I don't understand you. I just said that you should use the Mesh workbench to create the mesh because there you can adjust the mesh parameters like the maximal angular deviation from the original object. The better the mesh the less the display artifacts.
