*SECTION PRINT implemented for volume elements
Re: *SECTION PRINT implemented for volume elements
Postby bernd » Sat Feb 29, 2020 1:13 pm
compiles, but unit test failure ...
import Test, femtest.app.test_object
Test.runTestsFromModule(femtest.app.test_object)
test_00print (femtest.app.test_object.TestObjectCreate) ... ok
test_femobjects_make (femtest.app.test_object.TestObjectCreate) ... FAIL
test_00print (femtest.app.test_object.TestObjectType) ... ok
test_femobjects_derivedfromfem (femtest.app.test_object.TestObjectType) ... FAIL
test_femobjects_derivedfromstd (femtest.app.test_object.TestObjectType) ... FAIL
test_femobjects_isoftype (femtest.app.test_object.TestObjectType) ... FAIL
test_femobjects_type (femtest.app.test_object.TestObjectType) ... FAIL
FAIL: test_femobjects_make (femtest.app.test_object.TestObjectCreate)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/app/test_object.py", line 134, in test_femobjects_make
    self.assertEqual(len(analysis.Group), count_defmake - 1)
AssertionError: 49 != 50
FAIL: test_femobjects_derivedfromfem (femtest.app.test_object.TestObjectType)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/app/test_object.py", line 1274, in test_femobjects_derivedfromfem
    self.assertEqual(len(doc.Objects), testtools.get_defmake_count(False))
AssertionError: 45 != 46
FAIL: test_femobjects_derivedfromstd (femtest.app.test_object.TestObjectType)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/app/test_object.py", line 1517, in test_femobjects_derivedfromstd
FAIL: test_femobjects_isoftype (femtest.app.test_object.TestObjectType)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/app/test_object.py", line 574, in test_femobjects_isoftype
FAIL: test_femobjects_type (femtest.app.test_object.TestObjectType)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/app/test_object.py", line 375, in test_femobjects_type
Ran 7 tests in 1.251s
FAILED (failures=5)
>>> # App.setActiveDocument("TestObjectCreate")
Postby bernd » Sat Feb 29, 2020 1:22 pm
bernd wrote:
Sat Feb 29, 2020 12:54 pm
bernd wrote:
Sat Feb 29, 2020 11:22 am
the following look strange to me, as tie was implemented already ???
https://github.com/berndhahnebach/FreeC ... 091251R245
https://github.com/berndhahnebach/FreeC ... 091251R262
ahh these are fixes which should be made in master? I will go for a separate commit to fix it.
git commit 6ec33d50a
Postby bernd » Sat Feb 29, 2020 7:10 pm
separated the changes not related to section print
https://github.com/berndhahnebach/FreeC ... /4d07e1fab
UR_
Postby UR_ » Sat Feb 29, 2020 7:20 pm
AFAICR, dat file reading was added, because section print output from ccx goes into dat file.
After reading, text goes into text document, which should be a child of ccx result object.
Postby bernd » Mon Mar 09, 2020 7:17 am
ahh ok ...
did some code refactor in FEM lately. I did change the section print code in this regard ... https://github.com/berndhahnebach/FreeC ... t/a14ef486
Would you give it a try? Recreation of the example file may need to be done.
UR_
Postby UR_ » Tue Mar 10, 2020 7:57 am
Had to change Fem.qrc to get a build.
git commit 7f4bd8c0d
But now, no avail due serialization issue https://forum.freecadweb.org/viewtopic.php?f=18&t=44021
I think, I have to wait until this topic is solved.
Postby bernd » Wed Mar 11, 2020 5:55 am
back to normal ... means should work again ...
UR_
Postby UR_ » Wed Mar 11, 2020 10:19 am
Corrected one typo.
PR git commit 64aed40a1
test file updated:
eye.FCStd
(456.64 KiB) Downloaded 52 times
One issue left ATM. ccx_dat_file is no child of CCX_Results
Screenshot 001.png (27.24 KiB) Viewed 287 times
Should have a look at this.
Postby bernd » Wed Mar 11, 2020 11:36 am
great
check view provider of result mechanical how to collect childs. Than do not add the dat obj to the analysis. It would be twice in tree.
Postby bernd » Wed Apr 22, 2020 7:00 am
due to some changes in ccx writer lately, I hat do change some lines to get the section print rebased ...
new code looks like this:
https://github.com/berndhahnebach/FreeC ... d55d091251
