Challenge: Constant Velocity Joint (M. Gesik)
Re: Challenge: Constant Velocity Joint (M. Gesik)
Postby Kunda1 » Mon Mar 30, 2020 4:54 pm
jpg87 wrote:
Mon Mar 30, 2020 4:40 pm
I remade the video by simultaneously varying the angle between the entry and the exit from 25 ° to 41.8 °: we then see that the arms with toothed sector collide (see more?).
Sorry, don't mean to nit-pick, but could you please speed the video up ?
Postby chrisb » Mon Mar 30, 2020 5:41 pm
Thanks, very good! I would second Kund's proposal. You could show two or even 5 revolutions over the vide's time. The slowdown functionplus pause then would enable the viewer still to see the details.
Zolko
Postby Zolko » Mon Mar 30, 2020 5:59 pm
jpg87 wrote:
Mon Mar 30, 2020 12:47 pm
this weekend I couldn't resist the urge to try this mechanism with Asm3 WB. Here's what I get. Animation video:
http://help-freecad-jpg87.fr/02assembla ... layer.html
Nice, well done. Did you use the provided STL files or did you re-model the parts ? It seems that the teeth are interfering with each other, no ?
Here are videos of my assembly (only 1 arm, the 2 others would be similar)
http://downloads.zzaero.com/CVJoint_deflection.mp4
http://downloads.zzaero.com/CVJoint_rotation.mp4
jpg87
Postby jpg87 » Mon Mar 30, 2020 6:41 pm
It is done!
I will try to improve and do several laps.
I used the stl files as wallpaper and redrawn the parts in PartDesign WB.
For this, I created provisional assemblies in Asm3 WB to position the stl previously solidified in Part WB.
For the teeth, I used FCGear, but I had trouble adjusting it correctly with the original teeth.
Your videos show how it works. Well done.
Sorry, I have not yet tried your Asm4 workshop: I work rather from contacts between surfaces, which I find more "concrete", and that allows Asm3 at two levels of complexity.
My website : http://help-freecad-jpg87.fr updated 2020/09/21
ppemawm
Postby ppemawm » Mon Mar 30, 2020 11:38 pm
Thank you for the videos. An exact solution!
I am so jealous that I have not finished mine yet.
....this weekend I couldn't resist the urge to try this mechanism with Asm3 WB.
Thank you, too, for demonstrating the CV joint using ASM3. I appreciate how much effort it is to create the model.
I look forward to investigating ASM3 once it becomes a standard workbench accessible with the AddOn manager.
BTW these two models would make terrific FreeCAD splash screens provided proper attribution is given to the inventor.
Mark Szlazak
Postby Mark Szlazak » Tue Mar 31, 2020 12:52 am
My thoughts as well.
jpg87
Postby jpg87 » Tue Mar 31, 2020 6:00 am
... provided proper attribution is given to the inventor.
I completely agree !
looo
Postby looo » Tue Mar 31, 2020 4:54 pm
I tried to reconstruct the bevel-gear but it looks like it uses a different shape (not spherical-involute). Anyway, the pitch angle should be exactly 18° and the center should be at the center of the sphere. With 13 teeth it looks like a good approximation.
Bildschirmfoto von 2020-03-31 18-47-02.png (27.57 KiB) Viewed 401 times
adrianinsaval
Postby adrianinsaval » Wed Apr 01, 2020 2:15 am
Now imagine them animated as splash screen, it would be a totally unnecesary use of resources but you have to admit it would look cool 8-)
jpg87
Postby jpg87 » Thu Apr 02, 2020 6:36 am
Thank you looo, after various tests I reach the same conclusions :
