Need to design mixing valve (pay to forum or members)
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
kisolre
Re: Need to design mixing valve (pay to forum or members)
Postby kisolre » Tue May 19, 2020 11:09 pm
benc wrote:
Tue May 19, 2020 9:55 pm
Can you post the endview?
You mean the whole 10" like this?
benc
Postby benc » Wed May 20, 2020 12:33 am
Good enough. For some reason the aspect seems different. Maybe my eyes are strained.
Can we determine the width of the "nub" on the end and increase the grove diameter by the same amount?
Can you recommend someone who does 3D prints?
benc
Postby benc » Wed May 20, 2020 2:49 am
Freecam forum administrators -- is the paypal account for Jürgen ok for making a donation? Or would another account serve you better?
kkremitzki
Postby kkremitzki » Wed May 20, 2020 5:43 am
IMO https://liberapay.com/FreeCAD is best but others may chime in, there is also for example https://www.bountysource.com/teams/freecad
Postby chrisb » Wed May 20, 2020 5:49 am
Many thanks to benc but even more to kisolre who made this donation possible!
kisolre
Postby kisolre » Wed May 20, 2020 6:09 am
Not sure what exactly do you have in mind. Could you mark it over the image? It sounds like you want to remove those little protrusions? they are formed by the intersections of the cuts. Maybe just moving the cuts along the shaft will fix that? Because if the grove diameter is increased this will require different tool...
kisolre
Postby kisolre » Wed May 20, 2020 6:16 am
Shapeways ?
benc
Postby benc » Wed May 20, 2020 1:49 pm
The nub you marked is exactly what I was referring to. I believe those projections will be subject to advanced erosion much more than the surrounding think sections.
If we increase the diameter of the ball mill, but keep the same depth, that should increase throughput while eliminating these weak points.
benc
Postby benc » Wed May 20, 2020 1:53 pm
DeanY3 and Kisoire have both been working with me. These two Cadsters are excellent.
benc
Shapeways ?
That works. :-)
