[AppImage Packaging Issue] Dimensioning not working
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
Gary R
Post by Gary R »
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.21097 (Git) AppImageDim
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
All of a sudden the dimensioning in Techdraw doesn't work. I get a:
File does not exist
/:/dd/icons/linearDimension.svg
I tried rerunning the appimage installation but did not clear the problem. This looks like a bug in TechDraw and makes the workbench pretty well useless. Does anyone know how to filx this.
Gary R
Reason: Updated title for clarity
Gary R
Re: Dimensioning not working
Post by Gary R »
oops. Sorry. I forgot to include the file I was working on. See attachment.
Gary R.
H2_Injector_Capillary.FCStd
(26.99 KiB) Downloaded 116 times
wandererfan
Post by wandererfan »
Gary R wrote: Fri May 29, 2020 11:55 pm All of a sudden the dimensioning in Techdraw doesn't work. I get a:
File does not exist
Seems ok here with today's freecad-daily:
"dd/icons/linearDimension.svg" is from the old DrawingDimensioning workbench. It isn't used in TechDraw.
"Version: 0.19.21097 (Git) AppImageDim". What is an AppImageDim? Haven't run across that before.
2020/05/29
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: 3b4b2dc2e36575b5e06f8e2a158bfd0b597f4724
Python version: 3.6.9
Qt version: 5.9.5
Locale: English/Canada (en_CA)
Post by Kunda1 »
Moved to TD subforum
Gary R
Post by Gary R »
OK here is some update.
First - I upgraded to a newer appimage and still got the same problem. I can only surmise that the problem resides with my debian system. Any suggestions of where to look?
Second - Appimage is not updating the $HOME/. local/share/applications/ file. So the Help -> About Freecad information is not accurate.
Third - The KDE desktop icon isn't updated so looks for the wrong version. This is a minor annoyance but would be helpful if fixed.
Gary R
wandererfan
Kunda1 wrote: Sat May 30, 2020 3:08 pm Moved to TD subforum
Sounds more like AppImage packaging issue so far. Don't know where those go.
Re: [AppImage Packaging Issue] Dimensioning not working
Post by Kunda1 »
wandererfan wrote: Sat May 30, 2020 4:49 pm Sounds more like AppImage packaging issue so far. Don't know where those go.
Thanks, moved to the 'Install/Compile' > 'Packaging' subforum
triplus
Post by triplus »
Hi @Gary R
Looks like you are using Drawing Dimensioning workbench and its Linear Dimension command and not the TechDraw Dimension Length command. I would recommend for you to remove Drawing Dimensioning module altogether, as it is not a suitable choice anymore, when it comes to FreeCAD 0.19. After make sure you are in the TechDraw workbench and try out the TechDraw Dimension Length command again.
