HoWil wrote: ↑Sat Jun 20, 2020 3:55 pm
- If I select "Measure Distance" and select a point than "Button" for "First Element" gets disabled and the one for the "Second Element" gets selected. If I accidentally select a wrong first point, than it is not possible to simply select 'First Element' again or e.g. press Esc. "Reset" clears all my measurements I have done before... thats not an solution.
yes, I noticed that too. Needs to be fixed.
- Nice to see that this tool is further improved... but wouldn't it be better to join your efforts with Maurice and improve the caliper instead of getting the thousand and first new measurement tool. I am pretty sure Maurice would support it
I tried but he didn't want. Then I proposed this for GSoC but it was not chosen. So I did it myself, I need this tool: that's the very principle of open-source, scratching an itch. This should actually be in core FreeCAD, not as an addon-module. But Part's measure tool only measures 2 shapes, you can't measure a circle's diameter, a segment's length, or a distance between snap-points.
