GSoC Proposal: Extended functionality of Rebar Addon
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: GSoC Proposal: Extended functionality of Rebar Addon
Post by Suraj Dadral »
bernd wrote: Thu Jul 09, 2020 2:36 pm @balbros: thanks
in the regard of the views ... it should be possible not to show all rebars. See attached side view of a wall. A column would be similar.
Hi @bernd, @balrobs and @hardeeprai
For now, I created above issue here to do it later.
Thanks.
hardeeprai
Post by hardeeprai »
balrobs wrote: Thu Jul 09, 2020 1:22 pm It's a 2D reinforcement software which treats individual reinforcements in the different views ...
May I know the name of the software?
H.S.Rai
balrobs
Post by balrobs »
hardeeprai wrote: Fri Jul 10, 2020 2:16 am
The name is DIG CAD. it has been used in our office for many years and we are very satisfied with it. However, there is no 3D modeling with it, all reinforcements are drawn in 2D with the support of the software and your imagination.
amrit3701
Post by amrit3701 »
@Suraj,
Any updates/progress on dimensions? If you stuck in any problem please share here (don't hesitate to ask for help ;) ). Feedback from the community is very important to be a successful GSoC project.
Also, please updates your logs: https://wiki.freecadweb.org/User:Suraj_ ... SoC20/logs
Amritpal Singh
Github, Like my work, sponsor me!
Suraj Dadral
amrit3701 wrote: Wed Jul 22, 2020 7:13 pm @Suraj,
Hi @all
Sorry for being late to report here. Here are updates:
1. Create parametric object for reinforcement dimensioning as per this commit.
For automated dimensioning, we will be creating new dimension object for each rebar dimensioning. Although, this may increase the number of objects in document, but the benefit of using this method will be that user will be able to delete or modify generated dimensioning for each rebar.
2. [WIP] Create stirrup dimensioning as per this commit.
Sample output:
amrit3701 wrote: Wed Jul 22, 2020 7:13 pm Also, please updates your logs: https://wiki.freecadweb.org/User:Suraj_ ... SoC20/logs
Will update it soon. (by today)
Thanks,
Suraj Dadral
Hi all,
Update: Implement Stirrup labeling in Top/Bottom views.
- Implement adding Rebar Mark in dimension label
- Remove "Font" and "FontSize" property from ReinforcementDrawing object as this part is required in ReinforcementDimension object and is already there.
- Return drawing page object from function makeReinforcementDrawing() instead of only drawing svg.
- Add left/right/top/bottom offset point in ReinforcementDrawing and ReinforcementDimension objects to use for automated dimensioning. In ReinforcementDrawing object, these will points to next point that can be used to place reinforcement dimension label.
Sample output:
In above, if stirrup span axis is parallel to drawing plane normal, then stirrup dimension/label is placed mid point of middle edge of stirrup.
We can also do it like below:
Please, let me know which way looks good or we need to some modification.
To display rebar mark in above, I used DimensionFormat="%M %C%D" (M->rebar.Mark, C->rebar.Amount, D->rebar.Diameter). And added Mark property manually into Rebar objects.
I will make PR into FreeCAD repo, if adding Mark property (of type string) to rebar objects is fine.
Thanks,
Suraj Dadral
Suraj Dadral wrote: Thu Jul 23, 2020 8:21 pm I will make PR into FreeCAD repo, if adding Mark property (of type string) to rebar objects is fine.
Added Mark property to ArchRebar object as of this commit: https://github.com/SurajDadral/FreeCAD/ ... 008b43b491
Please check if this is right, I will create PR to FreeCAD repo then.
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Thu Jul 23, 2020 9:51 pm Added Mark property to ArchRebar object as of this commit: https://github.com/SurajDadral/FreeCAD/ ... 008b43b491
Create PR, please!
Amritpal Singh
Suraj Dadral
amrit3701 wrote: Fri Jul 24, 2020 7:19 am
Create PR, please!
It's done: https://github.com/FreeCAD/FreeCAD/pull/3730
Thanks,
balrobs
Post by balrobs »
Hi @Suraj
Suraj Dadral wrote: Thu Jul 23, 2020 8:21 pm Please, let me know which way looks good or we need to some modification.
IMHO the second way of dimensioning stirrups is more understandable. I've noticed that text sizes are different for both picture. In the first pic all views use the same font size. This is not true for the second pic. I think "equivalent" labels should have same text height and it should not depend on view scale.
BTW I tried to install your latest branch-dimensioning for testing it but I failed using the following code:
from ReinforcementDrawing import make_reinforcement_drawing
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Front")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Rear")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Left")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Right")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Top")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Bottom")
Obviously this depends on some last changes ... Could you please give me a hint how to test the new feature?
Thank you!
