FC Menu goes away after applying the Part WB Geometry Check and switching back to Part Design WB
tom
Postby tom » Sun Aug 02, 2020 11:43 am
on MacOS I see an issue with the FC menu after performing a geometry check in the Part WB and switching back to the Part Design WB. In that case the whole menu becomes empty:
Can anybody else reproduce the problem? Is it MacOS related or does it occur on other platforms too?
BR Tom
OS: macOS Mojave (10.14)
Version: 0.19.22164 (Git)
Hash: f2a9f712e8d68ee2393d0fe748c02096c4148a32
Python version: 3.8.5
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
Re: FC Menu goes away after applying the Part WB Geometry Check and switching back to Part Design WB
Postby chrisb » Sun Aug 02, 2020 3:50 pm
It seems to be the same issue that changes the possibility to toggle visibility in the tree. Can ou please check if there exists already an entry in the tracker?
As a workaround it helps to switch to another screen and back; so for me it is just two swipes and everything is back to normal.
tom
Postby tom » Sun Aug 02, 2020 8:29 pm
That is an interesting observation, which I wasn't aware of. I thought that the issue was QT related and only some menu redraw was missing. But now I checked your observation and indeed both effects are related to each other. So, it's more than just a redraw issue.
I didn't find anything.
Switching to another application and back to FC works too as a workaround. Thank you for that hint.
