Assembly4: XLink absolute filepath problem
aapo
Re: Assembly4: XLink absolute filepath problem
Postby aapo » Fri Nov 08, 2019 8:07 am
realthunder wrote:
Fri Nov 08, 2019 12:09 am
It got stuck in one of my feature branch. I have just split it out and submitted the PR here.
After this patch will be applied, will it be possible to load old Assembly4 files containing absolute filepaths; or will there be a need to convert the files somehow?
Reading the code in the patch leads me to think, that if it's possible to read an old FCStd file, then saving the file with the patch enabed should make the xlink paths relative. Thus, I'd think that a simple load and save would make any Assembly4 files "good", but is this true?
realthunder
Postby realthunder » Fri Nov 08, 2019 11:05 pm
Yes, just load and save. You may need to manually save all the linked documents, because they are not marked as changed. Just set each document as active, and save.
FCuser2019
Postby FCuser2019 » Mon Nov 11, 2019 8:51 pm
adrianinsaval wrote:
Thu Nov 07, 2019 9:51 pm
Sorry to bother you but are there any news on this front?
Thanks for this fix, FreeCAD_0.19-18714 works :)
project4
Postby project4 » Tue Aug 25, 2020 7:46 pm
Hi guys,
I'm facing exactly the same problem with asm4.
I'm with 0.19 pre-release daily build, so I guess the realthunder's fix should be in.
Is there anything I should check to make sure I have that fix?
My physical path include symbolic links and on some PCs also a NFS mount, that's probably that cause the problem along the way.
Will appreciate a fix or workaround for that problem.
Thanks.
Zolko
Postby Zolko » Tue Aug 25, 2020 8:06 pm
could you please try with the AppImage:
project4
Postby project4 » Wed Aug 26, 2020 6:39 am
Running from the latest AppImage gave the same results :(
More information here:
https://github.com/Zolko-123/FreeCAD_As ... /issues/95
realthunder
Postby realthunder » Wed Aug 26, 2020 8:33 am
PR submitted here for the fix.
Zolko
Postby Zolko » Wed Aug 26, 2020 8:49 am
hold-on, this doesn't look right:
We used to rely on QFileInfo::canonicalFilePath() to resolve it,
but has now been changed to simply use the absoluteFilePath()
We had absolute file paths before and that wasn't good either. Why not use filePath() ?
https://doc.qt.io/qt-5/qfileinfo.html
realthunder
Postby realthunder » Wed Aug 26, 2020 8:52 am
The absolute path is not used for saving, it is used as a key to lookup already loaded document. Just compare the documentation of QFileInfo::canonicalFilePath() and absoluteFilePath(), you'll know the difference.
Zolko
Postby Zolko » Wed Aug 26, 2020 8:56 am
Ah OK, thanks.
And what happens if we load the same document through different symlink-path into the assembly ?
